This has been broken for a few months for me and was wondering if this is a known issue and if there is a fix is on the horizon?
Hi @kgtree,
What version of Caddy are you trying to build, and what steps are you taking to build it?
I’m assuming Caddy v1 (because of the wording tls.dns.cloudflare
). I was able to successfully build Caddy v1.0.4 (h1:wwuGSkUHo6RZ3oMpeTt7J09WBB87X5o+IZN4dKehcQE=) with the plugin just now using the official build instructions: GitHub - caddyserver/caddy: Fast, multi-platform web server with automatic HTTPS
Hey @Whitestrake,
I should have specified, but I’m trying to build the Windows x64 1.0.4 version of Caddy using the download page (https://caddyserver.com/v1/download)
I’m actually trying to use Caddy with 2 plugins, cloudflare and reauth. What’s interesting is that I just tried building with just the Cloudflare plugin and it successfully built for me also. Previously I had just tried building with reauth and that also built successfully; which actually led me to assume the problem was with the cloudflare plugin. I should have been more thorough and not assumed that though, because if I try to build with either reauth or cloudflare alone I get a successful build prompt, but if I try to build Caddy with both plugins selected I get a prompt that one of the plugins is broken? Any idea why these two plugins are no longer compatible with each other?
Given the nature of plugins and how they (don’t) interact with each other… I’m not ruling incompatibility out as the cause, but I’d be far more inclined to think there’s an issue with the build server itself, which would require @matt to investigate.
I was able to easily build the binary with http.reauth
and tls.dns.cloudflare
included (log below).
~/Projects/test via 🐹 v1.13.8
➜ cat main.go
package main
import (
"github.com/caddyserver/caddy/caddy/caddymain"
// plug in plugins here, for example:
// _ "import/path/here"
_ "github.com/caddyserver/dnsproviders/cloudflare"
_ "github.com/freman/caddy-reauth"
func main() {
// optional: disable telemetry
// caddymain.EnableTelemetry = false
caddymain.Run()
➜ go mod init caddy
go: creating new go.mod: module caddy
➜ go get github.com/caddyserver/caddy
go: finding github.com/caddyserver/caddy v1.0.4
go: downloading github.com/caddyserver/caddy v1.0.4
go: extracting github.com/caddyserver/caddy v1.0.4
go: downloading github.com/flynn/go-shlex v0.0.0-20150515145356-3f9db97f8568
go: extracting github.com/flynn/go-shlex v0.0.0-20150515145356-3f9db97f8568
go: downloading github.com/google/uuid v1.1.1
go: extracting github.com/google/uuid v1.1.1
go: finding github.com/flynn/go-shlex v0.0.0-20150515145356-3f9db97f8568
go: finding github.com/google/uuid v1.1.1
➜ go build
go: finding github.com/freman/caddy-reauth latest
go: downloading github.com/freman/caddy-reauth v0.0.0-20191025011741-deaa60e56872
go: extracting github.com/freman/caddy-reauth v0.0.0-20191025011741-deaa60e56872
go: downloading github.com/allegro/bigcache v1.2.1
go: downloading github.com/hashicorp/go-getter v1.4.0
go: downloading gopkg.in/ldap.v2 v2.5.1
go: extracting github.com/hashicorp/go-getter v1.4.0
go: extracting github.com/allegro/bigcache v1.2.1
go: extracting gopkg.in/ldap.v2 v2.5.1
go: downloading github.com/aws/aws-sdk-go v1.23.0
go: downloading github.com/hashicorp/go-cleanhttp v0.5.0
go: downloading cloud.google.com/go v0.45.1
go: downloading github.com/bgentry/go-netrc v0.0.0-20140422174119-9fd32a8b3d3d
go: downloading google.golang.org/api v0.9.0
go: downloading github.com/mitchellh/go-homedir v1.1.0
go: downloading github.com/hashicorp/go-version v1.1.0
go: downloading github.com/mitchellh/go-testing-interface v1.0.0
go: extracting github.com/mitchellh/go-homedir v1.1.0
go: extracting github.com/mitchellh/go-testing-interface v1.0.0
go: extracting github.com/hashicorp/go-version v1.1.0
go: extracting github.com/bgentry/go-netrc v0.0.0-20140422174119-9fd32a8b3d3d
go: extracting github.com/hashicorp/go-cleanhttp v0.5.0
go: downloading github.com/ulikunitz/xz v0.5.5
go: downloading gopkg.in/asn1-ber.v1 v1.0.0-20181015200546-f715ec2f112d
go: extracting gopkg.in/asn1-ber.v1 v1.0.0-20181015200546-f715ec2f112d
go: downloading github.com/hashicorp/go-safetemp v1.0.0
go: extracting github.com/hashicorp/go-safetemp v1.0.0
go: extracting github.com/ulikunitz/xz v0.5.5
go: extracting cloud.google.com/go v0.45.1
go: downloading google.golang.org/genproto v0.0.0-20190819201941-24fa4b261c55
go: extracting google.golang.org/genproto v0.0.0-20190819201941-24fa4b261c55
go: downloading google.golang.org/grpc v1.21.1
go: extracting google.golang.org/grpc v1.21.1
go: downloading go.opencensus.io v0.22.0
go: extracting go.opencensus.io v0.22.0
go: downloading github.com/googleapis/gax-go/v2 v2.0.5
go: extracting github.com/googleapis/gax-go/v2 v2.0.5
go: extracting google.golang.org/api v0.9.0
go: downloading golang.org/x/oauth2 v0.0.0-20190604053449-0f29369cfe45
go: downloading github.com/hashicorp/golang-lru v0.5.3
go: extracting github.com/aws/aws-sdk-go v1.23.0
go: extracting github.com/hashicorp/golang-lru v0.5.3
go: extracting golang.org/x/oauth2 v0.0.0-20190604053449-0f29369cfe45
go: downloading github.com/jmespath/go-jmespath v0.0.0-20180206201540-c2b33e8439af
go: extracting github.com/jmespath/go-jmespath v0.0.0-20180206201540-c2b33e8439af
go: finding github.com/allegro/bigcache v1.2.1
go: finding gopkg.in/ldap.v2 v2.5.1
go: finding github.com/hashicorp/go-getter v1.4.0
go: finding gopkg.in/asn1-ber.v1 v1.0.0-20181015200546-f715ec2f112d
go: finding github.com/aws/aws-sdk-go v1.23.0
go: finding cloud.google.com/go v0.45.1
go: finding github.com/googleapis/gax-go/v2 v2.0.5
go: finding github.com/bgentry/go-netrc v0.0.0-20140422174119-9fd32a8b3d3d
go: finding github.com/hashicorp/go-cleanhttp v0.5.0
go: finding google.golang.org/grpc v1.21.1
go: finding github.com/hashicorp/go-safetemp v1.0.0
go: finding github.com/hashicorp/go-version v1.1.0
go: finding go.opencensus.io v0.22.0
go: finding github.com/mitchellh/go-homedir v1.1.0
go: finding google.golang.org/api v0.9.0
go: finding github.com/mitchellh/go-testing-interface v1.0.0
go: finding google.golang.org/genproto v0.0.0-20190819201941-24fa4b261c55
go: finding github.com/ulikunitz/xz v0.5.5
go: finding github.com/jmespath/go-jmespath v0.0.0-20180206201540-c2b33e8439af
go: finding golang.org/x/oauth2 v0.0.0-20190604053449-0f29369cfe45
go: finding github.com/hashicorp/golang-lru v0.5.3
~/Projects/test via 🐹 v1.13.8 took 30s 153ms
➜ ./caddy -version
➜ ./caddy -plugins
Server types:
http
Caddyfile loaders:
short
flag
default
Other plugins:
http.basicauth
http.bind
http.browse
http.errors
http.expvar
http.ext
http.fastcgi
http.gzip
http.header
http.index
http.internal
http.limits
http.log
http.markdown
http.mime
http.pprof
http.proxy
http.push
http.reauth
http.redir
http.request_id
http.rewrite
http.root
http.secrets
http.status
http.templates
http.timeouts
http.websocket
on
tls
tls.cluster.file
tls.dns.cloudflare
