Hey Caddy community! I’m not able to block all external traffic while only allowing internal traffic to reach my paperless-ngx. I’m using Wireguard (or rather wg-easy) to establish a VPN to my (VP)Server to access paperless-ngx, but it still sees me as external. Please guide me in the right direction as i am lost (and pretty new to this all).
I should VPN into the system with the IP-Adress 10.8.0.x/24-network.
Oct 11 05:01:04 ubuntu systemd[1]: Starting caddy.service - Caddy...
Oct 11 05:01:04 ubuntu caddy[41609]: caddy.HomeDir=/var/lib/caddy
Oct 11 05:01:04 ubuntu caddy[41609]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Oct 11 05:01:04 ubuntu caddy[41609]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Oct 11 05:01:04 ubuntu caddy[41609]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Oct 11 05:01:04 ubuntu caddy[41609]: caddy.Version=2.6.2
Oct 11 05:01:04 ubuntu caddy[41609]: runtime.GOOS=linux
Oct 11 05:01:04 ubuntu caddy[41609]: runtime.GOARCH=amd64
Oct 11 05:01:04 ubuntu caddy[41609]: runtime.Compiler=gc
Oct 11 05:01:04 ubuntu caddy[41609]: runtime.NumCPU=4
Oct 11 05:01:04 ubuntu caddy[41609]: runtime.GOMAXPROCS=4
Oct 11 05:01:04 ubuntu caddy[41609]: runtime.Version=go1.22.2
Oct 11 05:01:04 ubuntu caddy[41609]: os.Getwd=/
Oct 11 05:01:04 ubuntu caddy[41609]: LANG=C.UTF-8
Oct 11 05:01:04 ubuntu caddy[41609]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/snap/bin
Oct 11 05:01:04 ubuntu caddy[41609]: NOTIFY_SOCKET=/run/systemd/notify
Oct 11 05:01:04 ubuntu caddy[41609]: USER=caddy
Oct 11 05:01:04 ubuntu caddy[41609]: LOGNAME=caddy
Oct 11 05:01:04 ubuntu caddy[41609]: HOME=/var/lib/caddy
Oct 11 05:01:04 ubuntu caddy[41609]: INVOCATION_ID=66d7a55bab5b4bb88f6a3bf22fc054cf
Oct 11 05:01:04 ubuntu caddy[41609]: JOURNAL_STREAM=8:169544
Oct 11 05:01:04 ubuntu caddy[41609]: SYSTEMD_EXEC_PID=41609
Oct 11 05:01:04 ubuntu caddy[41609]: MEMORY_PRESSURE_WATCH=/sys/fs/cgroup/system.slice/caddy.service/memory.pressure
Oct 11 05:01:04 ubuntu caddy[41609]: MEMORY_PRESSURE_WRITE=c29tZSAyMDAwMDAgMjAwMDAwMAA=
Oct 11 05:01:04 ubuntu caddy[41609]: {"level":"info","ts":1728622864.251538,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Oct 11 05:01:04 ubuntu caddy[41609]: {"level":"info","ts":1728622864.2527974,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127
.0.0.1:2019"]}
Oct 11 05:01:04 ubuntu caddy[41609]: {"level":"warn","ts":1728622864.2529042,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_po
rt":80}
Oct 11 05:01:04 ubuntu caddy[41609]: {"level":"info","ts":1728622864.2530026,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00023bd50"}
Oct 11 05:01:04 ubuntu caddy[41609]: {"level":"info","ts":1728622864.2530506,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Oct 11 05:01:04 ubuntu caddy[41609]: {"level":"info","ts":1728622864.2530708,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc00023bd50"}
Oct 11 05:01:04 ubuntu caddy[41609]: {"level":"info","ts":1728622864.253084,"logger":"tls","msg":"finished cleaning storage units"}
Oct 11 05:01:04 ubuntu caddy[41609]: Error: loading initial config: loading new config: http app module: start: listening on :80: listen tcp :80: bind: address already in use
Oct 11 05:01:04 ubuntu systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Oct 11 05:01:04 ubuntu systemd[1]: caddy.service: Failed with result 'exit-code'.
Oct 11 05:01:04 ubuntu systemd[1]: Failed to start caddy.service - Caddy.
-- Boot 2595a465e3c44269990175a869d1b10d --
Oct 11 13:51:01 ubuntu systemd[1]: Starting caddy.service - Caddy...
Oct 11 13:51:02 ubuntu caddy[678]: caddy.HomeDir=/var/lib/caddy
Oct 11 13:51:02 ubuntu caddy[678]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Oct 11 13:51:02 ubuntu caddy[678]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Oct 11 13:51:02 ubuntu caddy[678]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Oct 11 13:51:02 ubuntu caddy[678]: caddy.Version=2.6.2
Oct 11 13:51:02 ubuntu caddy[678]: runtime.GOOS=linux
Oct 11 13:51:02 ubuntu caddy[678]: runtime.GOARCH=amd64
Oct 11 13:51:02 ubuntu caddy[678]: runtime.Compiler=gc
Oct 11 13:51:02 ubuntu caddy[678]: runtime.NumCPU=4
Oct 11 13:51:02 ubuntu caddy[678]: runtime.GOMAXPROCS=4
Oct 11 13:51:02 ubuntu caddy[678]: runtime.Version=go1.22.2
Oct 11 13:51:02 ubuntu caddy[678]: os.Getwd=/
Oct 11 13:51:02 ubuntu caddy[678]: LANG=C.UTF-8
Oct 11 13:51:02 ubuntu caddy[678]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/snap/bin
Oct 11 13:51:02 ubuntu caddy[678]: NOTIFY_SOCKET=/run/systemd/notify
Oct 11 13:51:02 ubuntu caddy[678]: USER=caddy
Oct 11 13:51:02 ubuntu caddy[678]: LOGNAME=caddy
Oct 11 13:51:02 ubuntu caddy[678]: HOME=/var/lib/caddy
Oct 11 13:51:02 ubuntu caddy[678]: INVOCATION_ID=4af3fbc4be9247ff893c8a5d43f26e3d
Oct 11 13:51:02 ubuntu caddy[678]: JOURNAL_STREAM=8:11836
Oct 11 13:51:02 ubuntu caddy[678]: SYSTEMD_EXEC_PID=678
Oct 11 13:51:02 ubuntu caddy[678]: MEMORY_PRESSURE_WATCH=/sys/fs/cgroup/system.slice/caddy.service/memory.pressure
Oct 11 13:51:02 ubuntu caddy[678]: MEMORY_PRESSURE_WRITE=c29tZSAyMDAwMDAgMjAwMDAwMAA=
Oct 11 13:51:02 ubuntu caddy[678]: {"level":"info","ts":1728654662.4313338,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Oct 11 13:51:02 ubuntu caddy[678]: {"level":"info","ts":1728654662.4431522,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0
.0.1:2019"]}
Oct 11 13:51:02 ubuntu caddy[678]: {"level":"warn","ts":1728654662.4433417,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port
":80}
Oct 11 13:51:02 ubuntu caddy[678]: {"level":"info","ts":1728654662.4434328,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0002ddb20"}
Oct 11 13:51:02 ubuntu caddy[678]: {"level":"info","ts":1728654662.4441922,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Oct 11 13:51:02 ubuntu caddy[678]: {"level":"info","ts":1728654662.444988,"logger":"tls","msg":"finished cleaning storage units"}
Oct 11 13:51:02 ubuntu caddy[678]: {"level":"info","ts":1728654662.4455442,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Oct 11 13:51:02 ubuntu caddy[678]: {"level":"info","ts":1728654662.4458385,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Oct 11 13:51:02 ubuntu caddy[678]: {"level":"info","ts":1728654662.4459343,"msg":"serving initial configuration"}
Oct 11 13:51:02 ubuntu systemd[1]: Started caddy.service - Caddy.
Oct 11 14:03:38 ubuntu caddy[678]: {"level":"info","ts":1728655418.9608684,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/stop","remote_ip":"127.0.0.1","remote_port":"42316","head
ers":{"Accept-Encoding":["gzip"],"Content-Length":["0"],"Origin":["http://localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
Oct 11 14:03:38 ubuntu caddy[678]: {"level":"warn","ts":1728655418.9609518,"logger":"admin.api","msg":"exiting; byeee!! 👋"}
Oct 11 14:03:38 ubuntu caddy[678]: {"level":"info","ts":1728655418.961549,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0002ddb20"}
Oct 11 14:03:38 ubuntu caddy[678]: {"level":"info","ts":1728655418.9617188,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
Oct 11 14:03:38 ubuntu caddy[678]: {"level":"info","ts":1728655418.9617305,"logger":"admin.api","msg":"shutdown complete","exit_code":0}
Oct 11 14:03:38 ubuntu systemd[1]: caddy.service: Deactivated successfully.
Ubuntu 24.04.1 LTS using docker compose version v2.29.7
docker compose up -d
proxy:
external: true
image: caddy:2
cap_add:
- NET_ADMIN
- 443:443
- ./data:/data
- ./config:/config
- proxy
While using the command:
root@ubuntu:~/caddy# docker compose exec caddy caddy fmt
Error: reading input file: open Caddyfile: no such file or directory
Caddyfile:
acme_ca https://acme-v02.api.letsencrypt.org/directory
email redacted@m-almeida.de
paperless.m-almeida.de {
@blocked not remote_ip private_ranges
respond @blocked 403
reverse_proxy paperless:8000
wireguard.m-almeida.de {
reverse_proxy wg-easy:51821
