1. Output of caddy version
v2.6.1 h1:EDqo59TyYWhXQnfde93Mmv4FJfYe00dO60zMiEt+pzo=
- MacOS on M1
- Docker (engine version
20.10.16
and compose version1.29.2
Standard command from the caddy container
wordpress:
image: wordpress:php8.1-fpm-alpine
WORDPRESS_DB_HOST: db
WORDPRESS_DB_USER: wordpress
WORDPRESS_DB_PASSWORD: wordpress
WORDPRESS_DB_NAME: wordpress
- wp_data:/var/www/html
depends_on:
db:
condition: service_healthy
- caddy
image: caddy:2.6.1-alpine
- "8080:8080"
- "8081:8081"
- "443:443/udp"
- caddy
db:
# We use a mariadb image which supports both amd64 & arm64 architecture
image: mariadb:10.6.4-focal
# If you really want to use MySQL, uncomment the following line
#image: mysql:9.0.27
- db_data:/var/lib/mysql
restart: always
- MYSQL_ROOT_PASSWORD=somewordpress
- MYSQL_DATABASE=wordpress
- MYSQL_USER=wordpress
- MYSQL_PASSWORD=wordpress
- '3309:3306'
- '33060:33060'
- caddy
healthcheck:
test: ["CMD", "mysqladmin", "ping", "--silent"]
timeout: 10s
retries: 20
driver: bridge
db_data:
wp_data:
localhost:8080 {
root * /var/www/html
php_fastcgi wordpress:9000
I’m trying to setup Wordpress with Caddy, when I started the containers with docker-compose up -d
everything is fine and I’m able to navigate to https://localhost:8080/wp-admin/install.php
however the static assets (CSS & JS) that Wordpress is trying to retrieve return a 404
resulting in the page being unstyled.
Attempting to retrieve one of the files with curl -v
gives the following output:
curl -v "https://localhost:8080/wp-includes/css/dashicons.min.css?ver=6.0.2"
* Trying ::1:8080...
* Connected to localhost (::1) port 8080 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* CAfile: /etc/ssl/cert.pem
* CApath: none
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (OUT), TLS alert, unknown CA (560):
* SSL certificate problem: unable to get local issuer certificate
* Closing connection 0
curl: (60) SSL certificate problem: unable to get local issuer certificate
how to fix it, please visit the web page mentioned above.
Bypassing curl’s TLS verification with the -k
flag for curl
gives the following result:
curl -vk "https://localhost:8080/wp-includes/css/dashicons.min.css?ver=6.0.2"
* ALPN, offering h2
* CApath: none
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-ECDSA-CHACHA20-POLY1305
* subject: [NONE]
* start date: Oct 12 11:22:01 2022 GMT
* expire date: Oct 12 23:22:01 2022 GMT
* issuer: CN=Caddy Local Authority - ECC Intermediate
* SSL certificate verify result: unable to get local issuer certificate (20), continuing anyway.
* Using Stream ID: 1 (easy handle 0x15b812400)
> GET /wp-includes/css/dashicons.min.css?ver=6.0.2 HTTP/2
> Host: localhost:8080
> user-agent: curl/7.77.0
> accept: */*
< HTTP/2 404
< alt-svc: h3=":8080"; ma=2592000
< server: Caddy
< content-length: 0
< date: Wed, 12 Oct 2022 11:32:45 GMT
I attempted to try with just HTTP
by changing my Caddyfile to be
http://localhost:8080 {
However, this led to the same result.
