2.2.1
Via Caddyfile
Ubuntu 20.04 LTS
#Inbound to XProtect HTTPS (192.168.100.100:8082)
xprotect.domain.co.uk {
tls /etc/ssl/certs/domain.co.uk.pem /etc/ssl/certs/domain.co.uk>
Strict-Transport-Security "max-age=31536000; includeSubdomains"
Referrer-Policy "same-origin"
php_fastcgi 127.0.0.1:9000
reverse_proxy {
to https://192.168.100.100:8082
tls
tls_insecure_skip_verify
So I am running Milestone’s XProtect through Caddy. Simply put I am having issues with the Websockets - Not that I fully understand why. On the XProtect Web interface, you can turn Websockets on/off. When going through Caddy, with Websockets ON I am not able to load previews of any camera. When I turn Websockets off, I am able to see the preview, however it’s more of a 2 second update of each camera (compared to live stream when Websockets are on).
I have stubbled across a post online, with a working NGINX config (URL below), however I don’t want to move across to NGINX, as I have learnt so much (and had success) with Caddy for more applications/uses than NGINX. The NGINX config is:
server {
listen 443 ssl;
ssl_certificate /etc/letsencrypt/live/<FQDN>/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/<FQDN>/privkey.pem;
server_name <FQDN>;
gzip off;
location / {
proxy_pass https://<MILESTONE IP>:8082;
proxy_buffering off;
proxy_http_version 1.1;
# Video uses WebSockets and needs special headers to work.
location /XProtectMobile/Video {
# These two headers come from the browser to NGINX, but they do
# not get passed through NGINX, so we will set them manually.
proxy_set_header Connection "Upgrade";
# These two headers do not come through from the browser as the
# Milestone server wants to see them, so we will set them manually.
proxy_set_header Host <MILESTONE IP>:8082;
proxy_set_header Origin https://<MILESTONE IP>:8082;
I would appreciate any help available on this!
I am not receiving any errors, as the config is correct, but just not functioning as well as I expect.
I have narrowed this down to Caddy, as when I load the website locally (or externally directly to the XProtect Server) all works as should (with Websockets turned on). However, if I then redirect through Caddy the issue then appears.
I have recently added the line
into my Caddyfile through research, but this doesn’t appear to have worked. Until 8 months ago I hadn’t touched Linux, let alone a reverse proxy, but I am slowly getting there!
https://vmalli.com/ssl-termination-for-milestone-xprotect-using-nginx/
