OS : Ubuntu 20.04.2 LTS (64 Bit)
Virt/Kernel : KVM / 5.4.0-29-generic
caddy run --watch
c. My complete Caddyfile or JSON config:
:80
encode gzip zstd
root * /root/frontend/dist
try_files {path}.html {path} /
route /backend/* {
uri strip_prefix /backend
reverse_proxy localhost:3000
Current config doesn’t work properly with vue-router, can obtain only page on /
vue-router works in history mode:
const router = new VueRouter({
mode: 'history',
base: process.env.BASE_URL,
routes
4. What I already tried:
Google returns non-working or outdated solutions, can’t find anything helpful in documentation
I think you want /index.html at the end, not /. I don’t think the file matcher (which is under the hood of the try_files directive) will do the fallback to the index.html, that’s typically file_server’s job (which happens after try_files.
Also, since you’re using try_files, you’ll want to wrap your two concerns with handle blocks for it to behave properly. Caddy sorts directives according to this predetermined directive order, so try_files happens before route, meaning that the URL will be rewritten by try_files before it reaches your reverse_proxy. This would work better:
encode gzip zstd
handle_path /backend/* {
try_files {path}.html {path} /index.html
Still doesn’t work. Returns layout with empty page.
Then at this point your problem is probably with your vue setup, which I can’t really help you with.
I don’t have enough information here to help further, there’s no evidence of a problem with Caddy.
