Caddy with UFW and autodrop of rules
v2.4.1 h1:kAJ0JB5Xk5gPdTH/27S5cyoMGqD5lBAe9yZ8zTjVJa0=
I’m running a very, very, very simple Caddy setup currently, with just one domain setup behind a reverse proxy with zstd and gzip compression enabled. My Caddyfile is below.
Ubuntu 20.04.2, using systemd
sudo service caddy start
Type=notify
https://cloak.lazinesspaysoff.org {
  reverse_proxy localhost:1080
  encode zstd gzip
I’m not having a problem, I’m trying to understand if something I’d like to do is possible. With nginx running with the Let’s Encrypt bot, I can set the bot to automatically drop my UFW firewall when it’s time to renew my SSL certificates, then it will re-enable the firewall once it’s completed its task.
My search on the internet hasn’t yielded any results in the ability to do such a thing. Is that possible with Caddy?
As mentioned, I already spent a while searching on Google using different terms to try and see if what I want is doable, as well as reading the automatic HTTPS page but came up blank.
It’s not possible at the moment. I am working on an event dispatching system that might make this viable in the future, but no promises.
What you could do though, is use the DNS challenge instead of the HTTP or ALPN challenges if you need your firewall set up. The DNS challenge gets around ACME providers needing to connect directly to your server, by indirectly verifying ownership of the domain by checking for a special DNS record that is generated during the issuance flow.
If your DNS provider isn’t supported, you could consider using the duckdns plugin to delegate the challenge.
Awesome, I’ll look into that thanks!
