Continuing the discussion from Symfony app under symlinked dir, subpath handled by file_server instead of php_fastcgi:
I can say now that even though I still have the symlink for browsing purposes, the handle directive is better to set a custom root just for this handle block.
However, there is still an issue.
I updated Caddy to v2.6.2, and I also updated the Caddyfile’s vhost:
demo.orbitale.io {
handle / {
root / /var/www/demo.orbitale.io/www/
file_server browse
# The app we're looking for
handle /orbitale_cms/* {
uri strip_prefix /orbitale_cms
root * /var/www/demo.orbitale.io/repos/demos.orbitale_cms/public/
php_fastcgi unix//run/php/php8.1-fpm.sock {
root /var/www/demo.orbitale.io/repos/demos.orbitale_cms/public/
# Fallback
php_fastcgi * unix//run/php/php8.1-fpm.sock
tls <redacted>
output file /var/www/demo.orbitale.io/access.log {
roll_size 512mb
roll_keep_for 720h
When I go to https://demo.orbitale.io/orbitale_cms/admin, an URL that can trigger Symfony’s backend, and it shows me a 404 not found: cannot find url /orbitale_cms/admin, so the Symfony backend is actually called.
If I just replace the whole index.php with solely phpinfo();, I see that the document root and script name are okay, but the REQUEST_URI still contains the wrong part even with the uri strip_prefix /orbitale_cms directive in the Caddyfile.
Am I forgetting something about this prefix? I found nothing relevant in the php_fastcgi expanded form ![]()
Edit: I even tried to copy/paste the expanded form and add the header_up X-Forwarded-Prefix /orbitale_cms directive, to see if it wasn’t a reverse-proxy issue or something, and it doesn’t do anything.
