Caddy with Perl FastCGI setup
Version 2
I have a production web site running on Windows IIS 10. with Perl CGI. All is well except is Windows and is very slow. I am hoping to migrate to Linux Ubuntu and convert CGI to FastCGI. I have a test server setup and can serve static HTML pages from Caddy. Https is working also. I am trying to figure out how to set up FastCGI with Perl. In IIS 10 I am using old style CGI. Any help would be appreciated to help me get to a “Hello World” with Caddy and FastCGI / Perl.
I installed Caddy using this tutorial
I am relatively new to Linux.
Ubuntu 22.04
No Docker
Perl v5.34.0
Paste command here.
        email not_my_real_email@gmail.com
hashlogger.com {
Initial setup of Perl FastCGI and example hello world script.
I placed a simple CGI script using FastCGI format into the root web server directory. I simply displayed the text.
#!/usr/bin/perl
use strict;
use CGI::Fast;
my $count = 0;
while (my $q = CGI::Fast->new) {
print(“Content-Type: text/plain\n\n”);
print("Process ID: $$; Count is: " . ++$count);
Hi Robert, welcome.
Just to be clear, FastCGI is different from CGI: you won’t have a lot of success using FastCGI without a FastCGI responder to run your app. (Like how PHP has php-fpm.)
But you can use the fastcgi transport easily enough without PHP-specific settings:
reverse_proxy backend:1234 {
    transport fastcgi
You will want to change backend:1234 to whatever your FastCGI responder is listening on. And you may need to add some settings within a new block after transport fastcgi. But that’s the basic idea.
