I have setup 2 container groups with Caddy as a side car container and they’re both running, in the frontend. The problem I have is that my requests to my backend are being sent through IP address and not using FQDN even after specifying in the proxy_pass.
I have tried curling the backend and realized the Fqdn works but using the IP doesn’t really work, it doesnt resolve.
2024/03/22 12:41:00 [error] 184#184: *1 SSL_do_handshake() failed (SSL: error:0A000438:SSL routines::tlsv1 alert internal error:SSL alert number 80) while SSL handshaking to upstream, client: 127.0.0.1, server: madiba-app.germanywestcentral.azurecontainer.io, request: "POST /auth/register HTTP/1.1", upstream: "https://4.182.8.54:443/auth/register", host: "madiba-app.germanywestcentral.azurecontainer.io", referrer: "https://madiba-app.germanywestcentral.azurecontainer.io/register"
127.0.0.1 - - [22/Mar/2024:12:41:00 +0000] "POST /auth/register HTTP/1.1" 502 497 "https://madiba-app.germanywestcentral.azurecontainer.io/register" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36" "10.92.0.11"
And a curl to the backend looks like this
mtsumi@DESKTOP-RCE5MCO:~$ curl -vk https://4.182.8.54:443/auth/register
* Trying 4.182.8.54:443...
* Connected to 4.182.8.54 (4.182.8.54) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* TLSv1.2 (IN), TLS header, Unknown (21):
* error:0A000438:SSL routines::tlsv1 alert internal error
* Closing connection 0
curl: (35) error:0A000438:SSL routines::tlsv1 alert internal error
mtsumi@DESKTOP-5MCO:~$ curl -vk https://madibapp.germanywestcentral.azurecontainer.io/auth/register
* Connected to madibapp.germanywestcentral.azurecontainer.io (4.182.8.54) port 443 (#0)
* ALPN, offering h2
* TLSv1.2 (IN), TLS header, Certificate Status (22):
* TLSv1.2 (IN), TLS header, Finished (20):
* TLSv1.2 (IN), TLS header, Supplemental data (23):
* TLSv1.2 (OUT), TLS header, Finished (20):
* TLSv1.2 (OUT), TLS header, Supplemental data (23):
* subject: CN=madibapp.germanywestcentral.azurecontainer.io
* start date: Mar 18 21:29:36 2024 GMT
* expire date: Jun 16 21:29:35 2024 GMT
* issuer: C=US; O=Let's Encrypt; CN=R3
* SSL certificate verify result: unable to get local issuer certificate (20), continuing anyway.
* Using Stream ID: 1 (easy handle 0x56113ca72eb0)
> GET /auth/register HTTP/2
> Host: madibapp.germanywestcentral.azurecontainer.io
> user-agent: curl/7.81.0
> accept: */*
< HTTP/2 405
< allow: POST
< content-type: application/json
< date: Fri, 22 Mar 2024 13:19:50 GMT
< server: Caddy
< server: uvicorn
< content-length: 31
* Connection #0 to host madibapp.germanywestcentral.azurecontainer.io left intact
{"detail":"Method Not Allowed"}
I am using Caddy from docker Caddy2.6
I am using Caddy image from docker, Caddy 2.6
Docker
N/A
Frontend
madiba-app.germanywestcentral.azurecontainer.io {
reverse_proxy http://localhost:3000
Backend
madibapp.germanywestcentral.azurecontainer.io {
reverse_proxy http://localhost:8000
Below is my nginx config
user nginx;
worker_processes 1;
error_log /var/log/nginx/error.log warn;
pid /var/run/nginx.pid;
events {
worker_connections 1024;
http {
include /etc/nginx/mime.types;
default_type application/octet-stream;
client_max_body_size 100M;
log_format main '$remote_addr - $remote_user [$time_local] "$request" '
'$status $body_bytes_sent "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for"';
access_log /var/log/nginx/access.log main;
sendfile on;
keepalive_timeout 65;
# SSL Configuration
server {
listen 3000;
server_name madiba-app.germanywestcentral.azurecontainer.io;
add_header Access-Control-Allow-Origin *;
location / {
root /app;
index index.html;
try_files $uri $uri/ /index.html;
resolver 8.8.8.8; # Use Google DNS resolver
set $api_backend https://madibapp.germanywestcentral.azurecontainer.io;
set $auth_backend https://madibapp.germanywestcentral.azurecontainer.io;
location /api/ {
proxy_pass $api_backend;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_connect_timeout 800s;
proxy_read_timeout 800s;
location /auth/ {
proxy_pass $auth_backend;
proxy_connect_timeout 300s;
proxy_read_timeout 300s;
error_page 500 502 503 504 /50x.html;
location = /50x.html {
root /usr/share/nginx/html;
