Caddy with Minio, Docker, Laravel
I am running Laravel Sail for my local dev, and it works fine with
app.localhost {
  	#tls internal
	reverse_proxy laravel.test
#what should I add here to link Caddy to MinIO?
I now have a MinIO container on the same docker network
and would like to have 2 buckets livewire-tmp and videos
What would this caddyfile look like?
    #docker-compose.yml
    laravel.test:
        image: 'sail-8.4/app'
            - '8888:80'
    minio:
        image: 'minio/minio:latest'
            - '9999:9000'
            - '8900:8900'
#laravel .env
MINIO_ACCESS_KEY=pass
MINIO_SECRET_KEY=pass
MINIO_REGION=us-east-1
MINIO_BUCKET=videos
#endpoint appears to be working, tested in laravel tinker
MINIO_ENDPOINT=http://minio:9999
#this I don't know if it's right or not
MINIO_URL=http://minio.localhost/videos
#laravel config/filesystems
    'disks' => [
        'minio' => [
            'driver' => 's3',
            'endpoint' => env('MINIO_ENDPOINT'),
            'key' =>      env('MINIO_ACCESS_KEY'),
            'secret' =>   env('MINIO_SECRET_KEY'),
            'bucket' =>   env('MINIO_BUCKET'),
            'region' =>   env('MINIO_REGION'),
            'url' =>      env('MINIO_URL'),
            'use_path_style_endpoint' => true,
My goal is to upload and deliver files from Caddy, without touching laravel for file delivery.
I just realized, I probably want to upload files to livewire-tmp normally and then after processing, move them to minio. So hopefully the Caddyfile can reflect this.
This seems like a Minio question.
