Caddy with .local subdomains
I have a Caddy setup I’ve been trying to do for 2 days, basically I have a laptop running headless debian connected to a wifi network. I have a bunch of docker containers running with various web UIs that I can access with the machine-ip:whatever-port…
I’ve learned about mDNS and I wanted to utilize that so I installed avahi-daemon and I can (mostly) find the device with debian.local for now.
So I set up Caddy so I can access the different web UIs using different subdomains, the reverse proxy with no subdomain works (no TLS though) but all the subdomain reverse proxies just don’t resolve whatsoever.
Firefox just says: “Hmm. We’re having trouble finding that site.”, here is curl error:
PS C:\Users\Psycho> curl dg.debian.local
curl : The remote name could not be resolved: 'dg.debian.local'
At line:1 char:1
+ curl dg.debian.local
    + CategoryInfo          : InvalidOperation: (System.Net.HttpWebRequest:HttpWebRequest) [Invoke-WebRequest], WebExcepti
   on
    + FullyQualifiedErrorId : WebCmdletWebResponseException,Microsoft.PowerShell.Commands.InvokeWebRequestCommand
v2.8.4
I installed Caddy following EXACTLY this: Install — Caddy Documentation (not docker, just a debian package)
Distributor ID: Debian
Description:    Debian GNU/Linux 12 (bookworm)
Release:        12
Codename:       bookworm
Tried both
caddy start
and currently running the service (non-api)
# domain name
        tls internal
debian.local {
        reverse_proxy 127.0.0.1:5001
dg.debian.local {
jf.debian.local {
        reverse_proxy 127.0.0.1:8096
js.debian.local {
        reverse_proxy 127.0.0.1:5055
rdr.debian.local {
        reverse_proxy 127.0.0.1:7878
snr.debian.local {
        reverse_proxy 127.0.0.1:8989
bzr.debian.local {
        reverse_proxy 127.0.0.1:6767
plr.debian.local {
        reverse_proxy 127.0.0.1:9696
qb.debian.local {
        reverse_proxy 127.0.0.1:8081
Howdy @Omar_Kamal, welcome to the Caddy community.
Sounds to me like your Debian host isn’t responding to mDNS requests for subdomains, only for its own actual hostname, which I assume is debian.local.
Caddy can’t really help with this; it can only really do its job once the client has resolved DNS and actually connects to it. Given that your clients aren’t even trying to connect to Caddy because they can’t resolve e.g. dg.debian.local, there’s nothing Caddy can do.
You’ll need to figure out how to get mDNS responding how you need, or maybe just configure your local DNS server directly.
