So having issue to get JIRA working with Caddy as reverse proxy
done the caddy file
mydomain.com {
gzip
proxy / localhost:8090
but I get browser message:
404 Site my domain.com is not served on this interface
what am i doing wrong?
done the caddy file
mydomain.com {
gzip
HI @Darren_Knipe, welcome to the Caddy community.
That error means that Caddy can’t find the domain you requested in the Caddyfile and doesn’t know what to do with it.
Make sure that Caddy is loading the correct Caddyfile on startup (-conf /path/to/Caddyfile
), and that the domain in the Caddyfile matches what you’re typing in your browser.
I found solution to be:
proxy / localhost:8090 {
policy round_robin
header_upstream Host {host}
header_upstream X-Forwarded-For {remote}
You can replace the last 4 header_upstreams with transparent.
Also, policy round_robin
has no effect here; it applies to proxies with multiple upstream targets.
A compact but equivalent version of your solution would be:
