): caddy:2-alpine
2. How I run Caddy: Running in a docker container next to a service
Dockerb. Command:
docker-compose up --force-recreate --build -d --remove-orphans
version: '3'
external: true
livekit:
image: "livekit/livekit-server"
restart: always
LIVEKIT_KEYS: "APImzH8pdMsUvj2: hMy34yUgIFRyDQhwQfUprjdDH5pvKzFV5jeZ9YXv5Il"
dev: null
node-ip: 23.95.166.25
expose:
- 7880
- 8000-10000
- "7880:7880"
- "7881:7881"
- "7882:7882/udp"
- caddy
image: caddy:2-alpine
- /data/caddy/Caddyfile:/etc/caddy/Caddyfile
- /data/caddy/data:/data
- /data/caddy/config:/config
- caddy
# Optional email key for lets encrypt
email clark@clarkeverson.com
#Optional staging lets encrypt for testing. Comment out for production.
#acme_ca https://acme-staging-v02.api.letsencrypt.org/directory
video.clarkeverson.com {
reverse_proxy localhost:7880
I am trying to run the above docker file and get it to point to an https: domain. When I run the docker if i access the site via the ip it gives me an ok, but the service requires https to run
docker logs cb33976c3dca
{"level":"info","ts":1642094967.9332201,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"warn","ts":1642094967.9352427,"msg":"input is not formatted with 'caddy fmt'","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
{"level":"info","ts":1642094967.938082,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
{"level":"info","ts":1642094967.938906,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0000da1c0"}
{"level":"info","ts":1642094967.9390614,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1642094967.9391088,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1642094967.9401004,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
{"level":"info","ts":1642094967.9414263,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1642094967.9415934,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["video.clarkeverson.com"]}
{"level":"info","ts":1642094967.942147,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1642094967.942166,"msg":"serving initial configuration"}
{"level":"info","ts":1642094967.9427993,"logger":"tls.obtain","msg":"acquiring lock","identifier":"video.clarkeverson.com"}
{"level":"info","ts":1642094967.946919,"logger":"tls.obtain","msg":"lock acquired","identifier":"video.clarkeverson.com"}
{"level":"info","ts":1642094968.372588,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["video.clarkeverson.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"clark@clarkeverson.com"}
{"level":"info","ts":1642094968.372696,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["video.clarkeverson.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"clark@clarkeverson.com"}
{"level":"info","ts":1642094968.5554833,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"video.clarkeverson.com","challenge_type":"http-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
{"level":"info","ts":1642094968.797444,"logger":"tls.issuance.acme","msg":"served key authentication","identifier":"video.clarkeverson.com","challenge":"http-01","remote":"3.19.56.43:60014","distributed":false}
{"level":"info","ts":1642094968.9792392,"logger":"tls.issuance.acme","msg":"served key authentication","identifier":"video.clarkeverson.com","challenge":"http-01","remote":"34.219.87.132:24524","distributed":false}
{"level":"info","ts":1642094969.014632,"logger":"tls.issuance.acme","msg":"served key authentication","identifier":"video.clarkeverson.com","challenge":"http-01","remote":"18.192.36.99:46410","distributed":false}
{"level":"info","ts":1642094969.6384957,"logger":"tls.issuance.acme","msg":"served key authentication","identifier":"video.clarkeverson.com","challenge":"http-01","remote":"66.133.109.36:26328","distributed":false}
{"level":"info","ts":1642094969.915655,"logger":"tls.issuance.acme.acme_client","msg":"validations succeeded; finalizing order","order":"https://acme-v02.api.letsencrypt.org/acme/order/362756650/55090385910"}
{"level":"info","ts":1642094970.289824,"logger":"tls.issuance.acme.acme_client","msg":"successfully downloaded available certificate chains","count":2,"first_url":"https://acme-v02.api.letsencrypt.org/acme/cert/036f8216602f37e8f92b6fde848aad943f92"}
{"level":"info","ts":1642094970.2911155,"logger":"tls.obtain","msg":"certificate obtained successfully","identifier":"video.clarkeverson.com"}
{"level":"info","ts":1642094970.291148,"logger":"tls.obtain","msg":"releasing lock","identifier":"video.clarkeverson.com"}
{"level":"error","ts":1642095030.246662,"logger":"http.log.error","msg":"dial tcp 127.0.0.1:7880: connect: connection refused","request":{"remote_addr":"167.94.138.59:50682","proto":"HTTP/1.1","method":"GET","host":"video.clarkeverson.com","uri":"/","headers":{"User-Agent":["Mozilla/5.0 (compatible; CensysInspect/1.1; +https://about.censys.io/)"],"Accept":["*/*"],"Accept-Encoding":["gzip"]},"tls":{"resumed":false,"version":772,"cipher_suite":4867,"proto":"","proto_mutual":true,"server_name":"video.clarkeverson.com"}},"duration":0.005500081,"status":502,"err_id":"jnf5242tm","err_trace":"reverseproxy.statusError (reverseproxy.go:886)"}
{"level":"error","ts":1642095030.3145401,"logger":"http.log.error","msg":"dial tcp 127.0.0.1:7880: connect: connection refused","request":{"remote_addr":"167.94.138.59:51924","proto":"HTTP/1.1","method":"GET","host":"video.clarkeverson.com","uri":"/","headers":{"Accept":["*/*"],"Accept-Encoding":["gzip"],"User-Agent":["Mozilla/5.0 (compatible; CensysInspect/1.1; +https://about.censys.io/)"]},"tls":{"resumed":false,"version":772,"cipher_suite":4867,"proto":"","proto_mutual":true,"server_name":"video.clarkeverson.com"}},"duration":0.00114496,"status":502,"err_id":"fpb68yjqn","err_trace":"reverseproxy.statusError (reverseproxy.go:886)"}
{"level":"error","ts":1642095032.8798296,"logger":"http.log.error","msg":"dial tcp 127.0.0.1:7880: connect: connection refused","request":{"remote_addr":"73.142.12.85:45708","proto":"HTTP/1.1","method":"GET","host":"video.clarkeverson.com","uri":"/rtc?access_token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJleHAiOjE2NDQ2ODcwMDksImlzcyI6IkFQSW16SDhwZE1zVXZqMiIsImp0aSI6ImNsYXJrIiwibmJmIjoxNjQyMDk1MDA5LCJzdWIiOiJjbGFyayIsInZpZGVvIjp7InJvb20iOiJteXJvb20iLCJyb29tSm9pbiI6dHJ1ZX19.Qp3L3i4Va-1-m-QowL2balCjgZXdk0x6I-tg_nhiNb4&protocol=5&sdk=js&version=0.15.3","headers":{"Connection":["Upgrade"],"Pragma":["no-cache"],"User-Agent":["Mozilla/5.0 (X11; Fedora; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/97.0.4692.71 Safari/537.36"],"Upgrade":["websocket"],"Origin":["https://example.livekit.io"],"Sec-Websocket-Version":["13"],"Accept-Encoding":["gzip, deflate, br"],"Accept-Language":["en-US,en;q=0.9"],"Sec-Websocket-Key":["poPia2An+hsjFzptUrWHcQ=="],"Cache-Control":["no-cache"],"Sec-Websocket-Extensions":["permessage-deflate; client_max_window_bits"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","proto_mutual":true,"server_name":"video.clarkeverson.com"}},"duration":0.001300496,"status":502,"err_id":"uizhuznkz","err_trace":"reverseproxy.statusError (reverseproxy.go:886)"}
{"level":"error","ts":1642095033.026339,"logger":"http.log.error","msg":"dial tcp 127.0.0.1:7880: connect: connection refused","request":{"remote_addr":"73.142.12.85:45712","proto":"HTTP/2.0","method":"GET","host":"video.clarkeverson.com","uri":"/rtc/validate?access_token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJleHAiOjE2NDQ2ODcwMDksImlzcyI6IkFQSW16SDhwZE1zVXZqMiIsImp0aSI6ImNsYXJrIiwibmJmIjoxNjQyMDk1MDA5LCJzdWIiOiJjbGFyayIsInZpZGVvIjp7InJvb20iOiJteXJvb20iLCJyb29tSm9pbiI6dHJ1ZX19.Qp3L3i4Va-1-m-QowL2balCjgZXdk0x6I-tg_nhiNb4&protocol=5&sdk=js&version=0.15.3","headers":{"Origin":["https://example.livekit.io"],"Sec-Fetch-Mode":["cors"],"Referer":["https://example.livekit.io/"],"Sec-Gpc":["1"],"Accept":["*/*"],"Sec-Fetch-Site":["cross-site"],"Sec-Fetch-Dest":["empty"],"Accept-Encoding":["gzip, deflate, br"],"Accept-Language":["en-US,en;q=0.9"],"User-Agent":["Mozilla/5.0 (X11; Fedora; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/97.0.4692.71 Safari/537.36"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"video.clarkeverson.com"}},"duration":0.001080132,"status":502,"err_id":"pkt7dfndn","err_trace":"reverseproxy.statusError (reverseproxy.go:886)"}
{"level":"error","ts":1642095116.6592171,"logger":"http.log.error","msg":"dial tcp 127.0.0.1:7880: connect: connection refused","request":{"remote_addr":"73.142.12.85:45714","proto":"HTTP/2.0","method":"GET","host":"video.clarkeverson.com","uri":"/","headers":{"Cache-Control":["max-age=0"],"Upgrade-Insecure-Requests":["1"],"Sec-Gpc":["1"],"Sec-Fetch-Site":["none"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-Dest":["document"],"Accept-Language":["en-US,en;q=0.9"],"User-Agent":["Mozilla/5.0 (X11; Fedora; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/97.0.4692.71 Safari/537.36"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"Sec-Fetch-User":["?1"],"Accept-Encoding":["gzip, deflate, br"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"video.clarkeverson.com"}},"duration":0.001169885,"status":502,"err_id":"wsu35rzhw","err_trace":"reverseproxy.statusError (reverseproxy.go:886)"}
{"level":"error","ts":1642095128.4322267,"logger":"http.log.error","msg":"dial tcp 127.0.0.1:7880: connect: connection refused","request":{"remote_addr":"179.43.169.181:57462","proto":"HTTP/1.1","method":"GET","host":"video.clarkeverson.com","uri":"/","headers":{"User-Agent":["Mozilla/5.0 (X11; Linux i686; rv:10.0) Gecko/20100101 Firefox/10.0"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","proto_mutual":true,"server_name":"video.clarkeverson.com"}},"duration":0.000954797,"status":502,"err_id":"tj0gf0a0z","err_trace":"reverseproxy.statusError (reverseproxy.go:886)"}
So i attempted to remove caddy to see if i could get the service working but then it gives an unsecure message. I have also reached out to the people that make the livekit tool but they don’t have caddy experience. This is my first attempt at docker compose
