Caddy with docker, DNS and LetsEncrypt
I’m trying to assess the caddy infrastructure and configuration and after reading the documentation, I’m left with a few questions regarding whether or not my desired configuration is possible.
Conditions
  1. Caddy is my reverse proxy for my docker applications
    • Caddy runs in LAN on docker host
    • LAN names use a publicly registered domain name and will connect directly
    • Remote clients will connect via VPN (netbird) and I don’t want to set up and/or configure a PKI.
  2. I have an internal authoritative DNS for serving A records to LAN (and VPN) clients
    • Server is BIND9 and I can use RFC 2136
  3. I have an external authoritative DNS for serving TXT records to LetsEncrypt
Expectation
What I am hoping for is that caddy can dynamically react to published docker services and update the internal DNS and retrieve and manage certificates for those services.
Results of my research
  1. Caddy is subtly complex and extremely versatile and powerful and much more than the simple proxy that it is perceived to be.
  2. Caddy supports various DNS providers, including RFC 2136
  3. The extension caddy-docker-upstreams provides the ability to use Docker labels to configure and publish services in caddy.
    • This appears to provide similar functionality as Traefik’s labels
The basics of LetsEncrypt integration and static reverse proxy configuration are well documented and I think I understand what I have to do.
Questions
  1. Is it possible to dynamically configure DNS resource records and LetsEncrypt certificates using just the docker labels?
  2. If it is possible, where can I find information about configuring dynamic provisioning A/AAAA/CNAME resource records in my DNS server?
    a. Is it standard if a DNS provider is globally defined?
Thanks for sharing any insights you may have.
This is a very popular plugin that uses Docker labels for hostnames and provisioning certs:
Do you mean something like this?
“dynamic_domains” was exactly what I was looking for.
