Hello this is my first time posting. I hope someone can help me as I feel like I am very close to having a working solution, but am missing something critical. I have checked many documents and related issues, but I am not able to implement an adequate solution. Hopefully this enough info to help troubleshoot.
I am unable to join my vaultwarden using the duck dns domain. Every time I enter in my domain from duck dns I get the following error “This site can’t be reached
Check if there is a typo in af-vw.duckdns.org”. I get this regardless of whether I try http or https. There doesn’t seem to be any explicit issues based on the logs as far as I can tell, so I am not sure if it an issue with caddy or my network settings.
log of connection to domain
curl -Iv http://af-vw.duckdns.org
* Could not resolve host: af-vw.duckdns.org
* Closing connection 0
curl -Iv https://af-vw.duckdns.org
log of my docker compose yml
docker compose -f vw_test.yml logs
vaultwarden | /--------------------------------------------------------------------\
vaultwarden | | Starting Vaultwarden |
vaultwarden | | Version 1.30.0 |
vaultwarden | |--------------------------------------------------------------------|
vaultwarden | | This is an *unofficial* Bitwarden implementation, DO NOT use the |
vaultwarden | | official channels to report bugs/features, regardless of client. |
vaultwarden | | Send usage/configuration questions or feature requests to: |
vaultwarden | | https://github.com/dani-garcia/vaultwarden/discussions or |
vaultwarden | | https://vaultwarden.discourse.group/ |
vaultwarden | | Report suspected bugs/issues in the software itself at: |
vaultwarden | | https://github.com/dani-garcia/vaultwarden/issues/new |
vaultwarden | \--------------------------------------------------------------------/
vaultwarden |
vaultwarden | [2023-11-26 18:04:26.033][start][INFO] Rocket has launched from http://0.0.0.0:80
caddy | {"level":"info","ts":1701021943.083372,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy | {"level":"warn","ts":1701021943.0857005,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
caddy | {"level":"info","ts":1701021943.0865426,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
caddy | {"level":"info","ts":1701021943.086875,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0003a0e80"}
caddy | {"level":"info","ts":1701021943.0869431,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
caddy | {"level":"info","ts":1701021943.0870168,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
caddy | {"level":"info","ts":1701021943.087364,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
caddy | {"level":"info","ts":1701021943.087508,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details."}
caddy | {"level":"info","ts":1701021943.0873716,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
caddy | {"level":"info","ts":1701021943.0877488,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
caddy | {"level":"info","ts":1701021943.0879407,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
caddy | {"level":"info","ts":1701021943.0880008,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["af-vw.duckdns.org"]}
caddy | {"level":"info","ts":1701021943.0882382,"logger":"tls","msg":"finished cleaning storage units"}
caddy | {"level":"info","ts":1701021943.0887532,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
caddy | {"level":"info","ts":1701021943.088764,"msg":"serving initial configuration"}
This is the output of my custom caddy build based on this guide
https://github.com/dani-garcia/vaultwarden/wiki/Running-a-private-vaultwarden-instance-with-Let%27s-Encrypt-certs
caddy run --envfile caddy.env
2023/11/26 19:12:22.626 INFO using adjacent Caddyfile
2023/11/26 19:12:22.629 WARN Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies {"adapter": "caddyfile", "file": "Caddyfile", "line": 2}
2023/11/26 19:12:22.630 INFO admin admin endpoint started {"address": "localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2023/11/26 19:12:22.630 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc0005d7000"}
2023/11/26 19:12:22.630 INFO http.auto_https server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2023/11/26 19:12:22.630 INFO http.auto_https enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2023/11/26 19:12:22.630 INFO http enabling HTTP/3 listener {"addr": ":443"}
2023/11/26 19:12:22.630 INFO failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details.
2023/11/26 19:12:22.631 INFO http.log server running {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2023/11/26 19:12:22.631 INFO http.log server running {"name": "remaining_auto_https_redirects", "protocols": ["h1", "h2", "h3"]}
2023/11/26 19:12:22.631 INFO http enabling automatic TLS certificate management {"domains": ["af-vw.duckdns.org"]}
2023/11/26 19:12:22.632 INFO tls cleaning storage unit {"description": "FileStorage:/test/AF/.local/share/caddy"}
2023/11/26 19:12:22.632 INFO autosaved config (load with --resume flag) {"file": "/test/AF/.config/caddy/autosave.json"}
2023/11/26 19:12:22.632 INFO serving initial configuration
2023/11/26 19:12:22.633 INFO tls finished cleaning storage units
My OS is open media vault 6 (omv6; based on debian 11). I am running Caddy as a docker compose file with vaultwarden using the omv6 web GUI (Just a nice interface that uses docker compose -d up) . I downloaded and installed a custom caddy build from the following link using the amd64 build for duckdns. This custom build has been renamed caddy as per this guide. The custom build lives in the same directory as the docker-compose.yml as specified in this guide
(https://github.com/dani-garcia/vaultwarden/wiki/Using-Docker-Compose#caddy-with-http-challenge)
I also have the build in the /usr/local/bin/ directory alongside a caddy.env file and a Caddyfile. My duckdns domain points to the ip address of the machine hosting everything.
I am using OMV6. I changed the ports of this to not use ports 80 and 443 so as to avoid port conflicts (which I was getting earlier).
cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
NAME="Debian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
Linux kernel info
uname -r
6.1.0-0.deb11.11-amd64
Docker compose up -d vw_test.yml
This is the Caddy yml that lives in the same directory as vw_test.yml
version: '3'
vaultwarden:
image: vaultwarden/server:latest
container_name: vaultwarden
restart: always
DOMAIN: "https://af-vw.duckdns.org" # Your domain; vaultwarden needs to know it's https to work properly with attachments
- ./vw-data:/data
image: caddy:2
restart: always
- 80:80 # Needed for the ACME HTTP-01 challenge.
- 443:443
- ./caddy:/usr/local/bin/caddy # Your custom build of Caddy.
- /Docker/vw_test/caddy_data:/data
- /Docker/vw_test/caddy_config:/config
DOMAIN: "https://af-vw.duckdns.org" # Your domain.
EMAIL: "myemailaddress" # The email address to use for ACME registration.
DUCKDNS_TOKEN: LONGDUCKDNSTOKEN
LOG_FILE: "/data/access.log"
This is my Caddyfile that lives in the same directory as vw_test.yml
{$DOMAIN}:443 {
level INFO
output file {$LOG_FILE} {
roll_size 10MB
roll_keep 10
# Use the ACME DNS-01 challenge to get a cert for the configured domain.
dns duckdns {$DUCKDNS_TOKEN}
# This setting may have compatibility issues with some browsers
# (e.g., attachment downloading on Firefox). Try disabling this
# if you encounter issues.
# Proxy everything to Rocket
reverse_proxy vaultwarden:80
I also have a Caddyfile that lives in /usr/local/bin/caddy
{$DOMAIN}:443 {
reverse_proxy localhost:8001
There is an associated caddy.env file with the following info
DOMAIN=https://af-vw.duckdns.org
DUCKDNS_TOKEN=LONGDUCKDNSTOKEN
