Caddy with Cloudflare
Hi all. I’m trying to replace my nginx server with a caddy server for local reverse proxy with Cloudflare. I seem to be stuck at the certificate. I can see I’m reaching Cloudflare because caddy is creating a TXT entry when I try to reach my local server.
Jan 24 22:23:48 caddy-test caddy[2047]: {"level":"info","ts":1769293428.8995705,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"pihole-pves.7263377.xyz"}
Jan 24 22:23:48 caddy-test caddy[2047]: {"level":"debug","ts":1769293428.8997962,"logger":"tls.obtain","msg":"trying issuer 1/1","issuer":"acme-v02.api.letsencrypt.org-directory"}
Jan 24 22:24:12 caddy-test caddy[2047]: {"level":"error","ts":1769293452.6969388,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"pihole-pves.7263377.xyz","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[pihole-pves.7263377.xyz] solving challenges: waiting for solver certmagic.solverWrapper to be ready: checking DNS propagation of \"_acme-challenge.pihole-pves.7263377.xyz.\" (relative=_acme-challenge.pihole-pves zone=7263377.xyz. resolvers=[192.168.31.20:53 192.168.31.21:53 192.168.31.22:53]): querying authoritative nameservers: dial tcp 162.159.44.99:53: i/o timeout (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/260529023/31005917793) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jan 24 22:24:12 caddy-test caddy[2047]: {"level":"error","ts":1769293452.6969793,"logger":"tls.obtain","msg":"will retry","error":"[pihole-pves.7263377.xyz] Obtain: [pihole-pves.7263377.xyz] solving challenges: waiting for solver certmagic.solverWrapper to be ready: checking DNS propagation of \"_acme-challenge.pihole-pves.7263377.xyz.\" (relative=_acme-challenge.pihole-pves zone=7263377.xyz. resolvers=[192.168.31.20:53 192.168.31.21:53 192.168.31.22:53]): querying authoritative nameservers: dial tcp 162.159.44.99:53: i/o timeout (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/260529023/31005917793) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":4,"retrying_in":300,"elapsed":395.339769645,"max_duration":2592000}
apt install -y debian-keyring debian-archive-keyring apt-transport-https curl
curl -1sLf ‘https://dl.cloudsmith.io/public/caddy/stable/gpg.key’ | gpg --dearmor -o /usr/share/keyrings/caddy-stable-archive-keyring.gpg
curl -1sLf ‘https://dl.cloudsmith.io/public/caddy/stable/debian.deb.txt’ | tee /etc/apt/sources.list.d/caddy-stable.list
chmod o+r /usr/share/keyrings/caddy-stable-archive-keyring.gpg
chmod o+r /etc/apt/sources.list.d/caddy-stable.list
apt update
apt install caddy
curl -o caddy ‘https://caddyserver.com/api/download?os=linux&arch=amd64&p=github.com%2Fcaddy-dns%2Fcloudflare’
systemctl stop caddy
chmod +x caddy
mv caddy /usr/bin/caddy
systemctl start caddy
nano /etc/caddy/.env
added the below to /etc/caddy/.env file
CLOUDFLARE_API_TOKEN=redacted_token
chmod 600 /etc/caddy/.env
chown caddy:caddy /etc/caddy/.env
systemctl edit caddy
Added the below to the caddy service
EnvironmentFile=/etc/caddy/.env
Debian 13 (trixie) AMD64 in a proxmox LXC
        acme_dns cloudflare {env.CLOUDFLARE_API_TOKEN}
pihole-pves.7263377.xyz {
        reverse_proxy 192.168.31.21:80
# domain name.
        root * /usr/share/caddy
        # php_fastcgi localhost:9000
This suggests that the Cloudflare authoritative DNS servers cannot be reached. Firewall?
By the way, you can remove everything below your site block, that is, the comments and the :80 block. :slight_smile:
That’s kind of what I was thinking, but nginx works without issue. Not sure how they differ in how they handle DNS challenge, but they seem work in very different ways.
