Hi folks.
First, thanks for the wonderful Caddy server. I have been learning about this and so far so good on regular setup with individual domains.
Currently, I have been trying to host third party subdomain on my caddy server. For e.g.,
abc.userdomain.com will point to abc.myowndomain.com. This will generate automatic HTTPS. In this, I have been stuck with the following problems. My apologies - I had to replace the actual domains with dummy ones. Hope this is ok.
myowndomain.com is owned by me.
userdomain.com is owned by user, not me.
Appreciate your help and time. Hope, you would be able to point me to the right direction.
I have been trying to enable automatic HTTPS for abc.userdomain.com that points to abc.myowndomain.com. I was able to enable HTTPS for abc.myowndomain.com. However, after mapping via CNAME in DNS, from abc.myowndomain.com to abc.userdomain.com, HTTPS is not working. Browsing it on a web browser, it returns ERR_TIMEOUT.
Apr 21 08:10:46 page caddy[1800243]: {"level":"error","ts":1745219446.2702575,"msg":"cleaning up solver","identifier":"abc.userdomain.com","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.abc.userdomain.com\" (usually OK if presenting also failed)","stacktrace":"github.com/mholt/acmez/v3.(*Client).solveChallenges.func1\n\tgithub.com/mholt/acmez/v3@v3.0.0/client.go:318\ngithub.com/mholt/acmez/v3.(*Client).solveChallenges\n\tgithub.com/mholt/acmez/v3@v3.0.0/client.go:363\ngithub.com/mholt/acmez/v3.(*Client).ObtainCertificate\n\tgithub.com/mholt/acmez/v3@v3.0.0/client.go:136\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).doIssue\n\tgithub.com/caddyserver/certmagic@v0.21.6/acmeissuer.go:477\ngithub.com/caddyserver/certmagic.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/certmagic@v0.21.6/acmeissuer.go:371\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue\n\tgithub.com/caddyserver/caddy/v2@v2.9.1/modules/caddytls/acmeissuer.go:249\ngithub.com/caddyserver/certmagic.(*Config).obtainCert.func2\n\tgithub.com/caddyserver/certmagic@v0.21.6/config.go:626\ngithub.com/caddyserver/certmagic.doWithRetry\n\tgithub.com/caddyserver/certmagic@v0.21.6/async.go:104\ngithub.com/caddyserver/certmagic.(*Config).obtainCert\n\tgithub.com/caddyserver/certmagic@v0.21.6/config.go:700\ngithub.com/caddyserver/certmagic.(*Config).ObtainCertAsync\n\tgithub.com/caddyserver/certmagic@v0.21.6/config.go:505\ngithub.com/caddyserver/certmagic.(*Config).obtainOnDemandCertificate\n\tgithub.com/caddyserver/certmagic@v0.21.6/handshake.go:538\ngithub.com/caddyserver/certmagic.(*Config).getCertDuringHandshake\n\tgithub.com/caddyserver/certmagic@v0.21.6/handshake.go:376\ngithub.com/caddyserver/certmagic.(*Config).GetCertificateWithContext\n\tgithub.com/caddyserver/certmagic@v0.21.6/handshake.go:92\ngithub.com/caddyserver/caddy/v2/modules/caddytls.(*ConnectionPolicy).buildStandardTLSConfig.func1\n\tgithub.com/caddyserver/caddy/v2@v2.9.1/modules/caddytls/connpolicy.go:276\ncrypto/tls.(*Config).getCertificate\n\tcrypto/tls/common.go:1196\ncrypto/tls.(*serverHandshakeStateTLS13).pickCertificate\n\tcrypto/tls/handshake_server_tls13.go:475\ncrypto/tls.(*serverHandshakeStateTLS13).handshake\n\tcrypto/tls/handshake_server_tls13.go:61\ncrypto/tls.(*Conn).serverHandshake\n\tcrypto/tls/handshake_server.go:54\ncrypto/tls.(*Conn).handshakeContext\n\tcrypto/tls/conn.go:1568\ncrypto/tls.(*Conn).HandshakeContext\n\tcrypto/tls/conn.go:1508\nnet/http.(*conn).serve\n\tnet/http/server.go:1971"}
Apr 21 08:10:46 page caddy[1800243]: {"level":"debug","ts":1745219446.6358094,"msg":"http request","method":"POST","url":"https://acme.zerossl.com/v2/DV90/authz/pTn5hGBGSxoPQjxiVjmX5w","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.9.1 CertMagic acmez (linux; amd64)"]},"response_headers":{"Access-Control-Allow-Origin":["*"],"Cache-Control":["max-age=0, no-cache, no-store"],"Content-Length":["134"],"Content-Type":["application/json"],"Date":["Mon, 21 Apr 2025 07:10:46 GMT"],"Link":["<https://acme.zerossl.com/v2/DV90>;rel=\"index\""],"Replay-Nonce":["9ZOzcn5jhXs6mCuUilE2q0GkrisoyvjxEHJyYPSWT-s"],"Server":["nginx"],"Strict-Transport-Security":["max-age=15724800; includeSubDomains"]},"status_code":200}
Apr 21 08:10:46 page caddy[1800243]: {"level":"error","ts":1745219446.6376493,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"abc.userdomain.com","issuer":"acme.zerossl.com-v2-DV90","error":"[abc.userdomain.com] solving challenges: presenting for challenge: adding temporary record for zone \"userdomain.com.\": got error status: HTTP 400: [{Code:6003 Message:Invalid request headers ErrorChain:[{Code:6111 Message:Invalid format for Authorization header}]}] (order=https://acme.zerossl.com/v2/DV90/order/h7gWs_w0zxzFp7owRAqmuQ) (ca=https://acme.zerossl.com/v2/DV90)"}
Apr 21 08:10:46 page caddy[1800243]: {"level":"debug","ts":1745219446.6385844,"logger":"events","msg":"event","name":"cert_failed","id":"46afee1b-771f-40f9-b351-e789943caddd","origin":"tls","data":{"error":{},"identifier":"abc.userdomain.com","issuers":["acme-v02.api.letsencrypt.org-directory","acme.zerossl.com-v2-DV90"],"renewal":false}}
Apr 21 08:10:46 page caddy[1800243]: {"level":"error","ts":1745219446.6405444,"logger":"tls.obtain","msg":"will retry","error":"[abc.userdomain.com] Obtain: [abc.userdomain.com] solving challenges: presenting for challenge: adding temporary record for zone \"userdomain.com.\": got error status: HTTP 400: [{Code:6003 Message:Invalid request headers ErrorChain:[{Code:6111 Message:Invalid format for Authorization header}]}] (order=https://acme.zerossl.com/v2/DV90/order/h7gWs_w0zxzFp7owRAqmuQ) (ca=https://acme.zerossl.com/v2/DV90)","attempt":2,"retrying_in":120,"elapsed":64.537514089,"max_duration":2592000}
Apr 21 08:12:42 page caddy[1800243]: {"level":"info","ts":1745219562.0930731,"logger":"tls.obtain","msg":"releasing lock","identifier":"abc.userdomain.com"}
Apr 21 08:12:42 page caddy[1800243]: {"level":"debug","ts":1745219562.0999882,"logger":"http.stdlib","msg":"http: TLS handshake error from 116.86.23.114:59686: context canceled"}
Install Caddy and xCaddy for Cloudflare DNS
sudo apt update
sudo apt install caddy
curl -1sLf 'https://dl.cloudsmith.io/public/caddy/xcaddy/gpg.key' | sudo gpg --dearmor -o /usr/share/keyrings/caddy-xcaddy-archive-keyring.gpg
curl -1sLf 'https://dl.cloudsmith.io/public/caddy/xcaddy/debian.deb.txt' | sudo tee /etc/apt/sources.list.d/caddy-xcaddy.list
sudo apt update
sudo apt install xcaddy
Ubuntu 20.04.6 LTS, x86-64
Systemd:
systemd 245 (245.4-4ubuntu3.24)
+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid
sudo systemctl status caddy
sudo systemctl restart caddy
on_demand_tls {
ask http://localhost:5555/
email me@myowndomain.com
acme_dns cloudflare {env.CLOUDFLARE_API_KEY}
(app) {
output stdout
# Resolve the root directory for the app
root * /home/ubuntu/apps/myowndomain.com/public
# Provide Zstd and Gzip compression
encode zstd gzip
# Allow caddy to serve static files
file_server {
index index.html
# Enable PHP-FPM
php_fastcgi unix//run/php/php8.4-fpm.sock
header -Server
http://, https:// {
on_demand
import app
http://localhost:5555 {
respond 200
