Hi!
So this is a bit of a weird question, but every time I go to a page of the caddy main website or documentation, it’s a 50/50 chance whether the page actually loads or returns 425. A refresh or two fixes it every single time. No other website is affected for me.
The caddy official website and documentation frequently returns Http 425
HTTP 425
This is because our server enable 0-RTT, and Chromium is buggy and does not retry requests with 425 responses as it should (which mean “you tried to make a request before the TLS handshake completed so we can’t validate your IP address”). In fact, we just merged a feature to disable 0-RTT to work around this caddyhttp: Option to disable 0-RTT by francislavoie · Pull Request #7485 · caddyserver/caddy · GitHub but this is unfortunate because it’s not Caddy’s fault, Chromium broke it. See Chromium
I have a problem with Caddy returning 425 error when running the docker tag caddy:alpine - however caddy:2.10-alpine does not return the same error.
This is with Caddy configured to do a simple proxy to a web server.
EDIT: Disregard… For some reason, my tests weren’t able to trigger it as easily in Caddy 2.11.x. The problem still occurs with 2.10.x as well as expected…
