I’m using caddy with the webdav plugin(GitHub - mholt/caddy-webdav: WebDAV handler module for Caddy) to set up a webdav server. I want to serve several directories for example dir1, dir2, dir3. So when I visit /dir1 it should return the contents for dir1. When I visit /, it should display dir1, dir2, dir3. I know I can do it via symbolic links, but I’d like to do it via a custom xml file. I tried to return a custom xml file when I visit / and the returned xml file contained those three directories. But it won’t work. The webdav client simply gets empty folder and won’t show the dir1, dir2 and dir3.
N/A
v2.7.6
I directly download the complied caddy binary file with the webdav plugin.
windows 11
N/A
order webdav before file_server
:2015 {
root /dir1/* /path/to/dir1/
root /dir2/* /path/to/dir2/
root /* index.xml
basicauth {
user1 hashed_password
webdav
