`caddy` w/ `caddy-l4` and proxying udp
I am trying to setup headscale[1] behind caddy with caddy-l4 module/plugin. I have been successful in proxying the tcp ports, but I am struggling with the udp port.
What I am trying to achieve:
  • udp/3478 (caddy) → udp/13478 (headscale)
N/A
From what I observe in journalctl -u caddy --no-pager | less +G there are no log statements indicating traffic on udp/3478 is proxied to 127.0.0.1:13478
Installed using NixOS module – nixpkgs/nixos/modules/services/web-servers/caddy/default.nix at nixos-26.05 · NixOS/nixpkgs · GitHub, which generates configuration and systemd service unit.
NixOS 26.11 (x86_64), caddy managed with systemd
# from systemd service unit
ExecStart=/nix/store/9nf7n51c8y8h9pyjw4b8jclh5m85zqyq-caddy-2.11.4/bin/caddy run --environ --config /etc/caddy/Caddyfile
# caddy.service
# for your installation.
Type=notify
ExecReload=/nix/store/9nf7n51c8y8h9pyjw4b8jclh5m85zqyq-caddy-2.11.4/bin/caddy reload --config /etc/caddy/Caddyfile --force
        layer4 {
                udp/:3478 {
                        route {
                                tls
                                proxy udp/127.0.0.1:13478
        servers :443 {
                protocols h1
        servers {
                listener_wrappers {
                        layer4 {
                                @tls tls
                                route @tls {
                                        subroute {
                                                @clients tls sni mesh.ryz.dev
                                                route @clients {
                                                        tls
                                                        proxy {
        upstream tcp/127.0.0.1:5443 {
        tls_server_name mesh.ryz.dev
        tls
                        tls
                level DEBUG
mesh.ryz.dev {
        tls /var/lib/acme/mesh.ryz.dev/cert.pem /var/lib/acme/mesh.ryz.dev/key.pem
                output file /var/log/caddy/access-mesh.ryz.dev.log
        reverse_proxy https://127.0.0.1:5443 {
fyi: configuration is correct. I sent test messages to udp/3478 via nc –u mesh.ryz.dev 3478 and observe log messages in caddy logs on udp/3478.
However, observed headscale will directly advertise the listening address and port change – udp/0.0.0.0:3478 → udp/127.0.0.1:13478 – to tailnet clients (but they will fail to connect due to firewall). Which is why I did not observe traffic in caddy logs. Should have heeded the “Limitations” [1] section of documentation.
On another note:
A reverse proxy adds another layer of complexity that needs to be able to handle the Tailscale Control Protocol properly. Be sure to test your setup without a reverse proxy before raising an issue.
In the caddy logs with aforementioned configuration, I observe these messages:
# journalctl -u caddy --no-pager | less +G
Jul 06 19:23:42 nabob caddy[28335]: {"level":"debug","ts":1783365822.65814,"logger":"http.handlers.reverse_proxy","msg":"upgrading connection","upstream":"127.0.0.1:5443","duration":0.020126754,"request":{"remote_ip":"...","remote_port":"64798","client_ip":"...","proto":"HTTP/1.1","method":"POST","host":"127.0.0.1:5443","uri":"/ts2021","headers":{"Connection":["Upgrade"],"X-Forwarded-Host":["mesh.ryz.dev:443"],"User-Agent":["Go-http-client/1.1"],"Content-Length":["0"],"X-Forwarded-For":["..."],"Upgrade":["tailscale-control-protocol"],"X-Tailscale-Handshake":["..."],"X-Forwarded-Proto":["https"],"Via":["1.1 Caddy"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","server_name":"mesh.ryz.dev","ech":false}},"http_version":1}
..."logger":"http.handlers.reverse_proxy","msg":"upgrading connection" ...
Is it safe to assume this is upgrading connection to websocket as per requirement [2]?
The reverse proxy must be configured to support WebSockets in order to communicate with Tailscale clients and it needs to handle two peculiarities of the Tailscale Control Protocol:
Or do I need to configure this explicitly in Caddyfile?
[1] Reverse proxy - Headscale
[2] Reverse proxy - Headscale
