2.5.1
Systemd as caddy user
Linux ip-172-31-29-132 5.13.0-1022-aws #24~20.04.1-Ubuntu SMP Thu Apr 7 22:10:15 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
service caddy start
After=network-online.target remote-fs.target nginx.service
Requires=nginx.service
Type=notify
Restart=on-abort
Environment=CADDYPATH=/etc/ssl/caddy/v2
; Always set "-root" to something safe in case it gets forgotten in the Caddyfile.
ExecStart=/usr/bin/caddy run --environ --config /etc/caddy/Caddyfile_v2 -watch
ExecReload=/usr/bin/caddy reload --config /etc/caddy/Caddyfile_v2 -watch
; Use graceful shutdown with a reasonable timeout
KillMode=mixed
KillSignal=SIGQUIT
; Unmodified caddy is not expected to use more than that.
LimitNPROC=2048
PrivateDevices=false
ProtectHome=true
ReadWriteDirectories=/etc/ssl/caddy/v2
# Global Options
admin off
order rate_limit before basicauth
on_demand_tls {
ask https://sites.example.com/allowed
interval 2m
burst 20
grace_period 10m
storage file_system /etc/ssl/caddy/v2
:443 {
on_demand
reverse_proxy @geofilter http://127.0.0.1:7777
@geofilter {
maxmind_geolocation {
db_path /etc/caddy/GeoLite2-Country.mmdb
deny_countries RU RO VN
rate_limit {
zone dynamic {
key {remote_host}
events 25
window 60s
uri replace s3.amazonaws.com/example static.example.com
encode {
gzip 9
match {
header Content-Type text/*
roll_size 25
roll_keep 10
roll_keep_for 7d
format filter {
wrap console {
time_format rfc3339
time_key timestamp
fields {
request>headers>Authorization delete
request>headers>Accept delete
#Include Redirs
import redir2/*
import redir2MultiDomain/*
We are migrating from Caddy V1 to Caddy V2
Our current issue seem to point to caddy trying to obtain certificates for domains listed in our redir directives and not only for those actual incoming requests.
As some of these domain may have been moved away from our cluster or are yet to be pointed at our cluster, this causes a number of certificate obtaining errors as the DNS is invalid.
Our understanding was that only requested domains would be verified against the ask endpoint, and not those in the configs
May 11 09:58:28 ip-172-31-29-132 caddy[11287]: {“level”:“error”,“ts”:1652263108.54393,“logger”:“tls.issuance.acme”,“msg”:“looking up info for HTTP challenge”,“host”:“www.example.com”,“error”:“no information found to solve challenge for identifier: www.example.com”}
May 11 09:57:47 ip-172-31-29-132 caddy[11287]: {“level”:“error”,“ts”:1652263067.306053,“logger”:“tls.obtain”,“msg”:“could not get certificate from issuer”,“identifier”:“example.com”,“issuer”:“acme-v02.api.letsencrypt.org-directory”,“error”:“HTTP 400 urn:ietf:params:acme:error:malformed - JWS verification error”}
This setup is working on a Caddy v1 cluster. We have updated the config to match the Caddy v2 directives.
We have not noticed this on v1 implementation.
We cross referenced this wiki article (Serving tens of thousands of domains over HTTPS with Caddy) to confirm that our config is setup as it should be
The redir files we have are as follows
example.com {
redir https://www.example.com:{uri} 301
