I have installed the Caddy v2 from the repository for Ubuntu/Debian/Arbian but now I have the doubt of knowing where the certificates are save.
If anyone can tell me the route I would appreciate it.
Thanks you
Thanks you
The storage locations are described here in the docs:
When installing with the apt repo, the caddy
user’s home directory is /var/lib/caddy
, so the files are stored relative to that path.
Okey, thanks you. I found it in cd $HOME/.local/share/caddy
