Caddy V2 + Varnish + Wordpress using Docker with SSL
First of all, I am noob in this stuff so do not be harsh. I would like to share my experience, because there are some pitfals in the process of deploying this stack and I spent a lot of hours tinkering with the caddyfile and docker-compose. I do not want others to tear their hair out when whey will try to accomplish this.
I am building this whole stuff on raspberry pi, so if you plan to do it on a different platform, you will have to use different containers.
Varnish is a caching service that creates static pages out of your dynamic site. The problem is it uses HTTP. So we need to configure it behind Caddy. So that Caddy could manage all the HTTPS stuff.
The scheme for connection would be:
Caddy:443 => Varnish:8090 => Caddy:8091 => Wordpress:9000
I assume you already have Docker and Docker-compose installed.
folder setup:
. Caddyfile
. .env
. docker-compose.yml
. php.ini
./caddy/Dockerfile
./varnish/default.vcl
docker-compose.yml:
version: '3.3'
  # Database
  database:
    image: linuxserver/mariadb
    container_name: database
      - ./db:/config
    restart: always
    env_file:
      - .env
      - MYSQL_DATABASE=blog_wp
      - MYSQL_ROOT_PASSWORD=$MYSQL_ROOT_PASSWORD
      - MYSQL_USER=$MYSQL_USER
      - MYSQL_PASSWORD=$MYSQL_PASSWORD
      - blog-network
  # Wordpress
  wordpress:
    depends_on:
      - database
    image: wordpress:php7.4-fpm-alpine
    container_name: wordpress
    restart: always
    user: "root:root"
    env_file:
      - .env
      - WORDPRESS_DB_HOST=database:3306
      - WORDPRESS_DB_USER=$MYSQL_USER
      - WORDPRESS_DB_PASSWORD=$MYSQL_PASSWORD
      - WORDPRESS_DB_NAME=blog_wp
      - ./php.ini:/usr/local/etc/php/conf.d/custom.ini
      - ./wordpress:/var/www/html
      - blog-network
  # Webserver
    container_name: webserver
    build:
      context: caddy
    restart: always
      - 443:443
      - ./caddy_data:/data
      - blog-network
  varnish:
    container_name: varnish
    image: viktorli/varnish_for_rpi:latest
      - ./varnish/default.vcl:/etc/varnish/default.vcl
      - blog-network
  blog-network:
    driver: bridge
Caddyfile:
	email you@mail.com
example.com {
	reverse_proxy varnish:8090  #IP of Docker host with Varnish LISTENING port
:8091 {
        @cachedFiles {
            path *.jpg *.jpeg *.png *.gif *.ico *.js *.css *.woff *.woff2 *.ttf
        header @cachedFiles Cache-Control "public, max-age=604800, must-revalidate"
        php_fastcgi wordpress:9000
default.vcl
# This is an example VCL file for Varnish.
# It does not do anything by default, delegating control to the
# builtin VCL. The builtin VCL is called when there is no explicit
# return statement.
# See the VCL chapters in the Users Guide at https://www.varnish-cache.org/docs/
# and https://www.varnish-cache.org/trac/wiki/VCLExamples for more examples.
# Marker to tell the VCL compiler that this VCL has been adapted to the
# new 4.0 format.
vcl 4.0;
# Default backend definition. Set this to point to your content server.
backend default {
    .host = "caddy";
    .port = "8091";
sub vcl_recv {
    # Happens before we check if we have this in cache already.
    # Typically you clean up the request here, removing cookies you don't need,
    # rewriting the request, etc.
if (req.restarts == 0) {
if (req.http.X-Forwarded-For) {
  set req.http.X-Forwarded-For = client.ip;
if (req.http.Authorization || req.method == "POST") {
  return (pass);
if (req.url ~ "/feed") {
  return (pass);
set req.http.cookie = regsuball(req.http.cookie, "wp-settings-\d+=[^;]+(; )?", "");
set req.http.cookie = regsuball(req.http.cookie, "wp-settings-time-\d+=[^;]+(; )?", "");
if (req.http.cookie == "") {
  unset req.http.cookie;
sub vcl_backend_response {
    # Happens after we have read the response headers from the backend.
    # Here you clean the response headers, removing silly Set-Cookie headers
    # and other mistakes your backend does.
sub vcl_deliver {
    # Happens when we have all the pieces we need, and are about to send the
    # response to the client.
    # You can do accounting or modifying the final object here.
ABOUT THE SETUP
As suggested by:
I did reconfigured docker-compose.yml and Caddyfile accordingly.
Now it is working.
Have you considered using this plugin instead?
You could drop Varnish altogether and just use one instance of Caddy. Seems like a mess to have 3 servers running instead of just one.
That said, I think a confusion you’re having with Docker has to do with how to refer to one service from another.
Docker ships with an internal DNS server that is configured to resolve service names to the container IP addresses. So instead of 192.168.200.184:9000, you should use wordpress:9000 and instead of localhost:80 you should use caddy:80, and so on.
I think that’s why bridge mode wasn’t working for you. Because localhost means “this container”.
Thank you for the input.
Does it generate static files from php?
Yes. But if you set network_mode: host in the docker-container then this DNS naming does not work. And Varnish itself does not seem to connect the correct way if it is not on the host machines network together with caddy. I do not know where is the problem.
No, cache-handler caches the responses in memory. It uses olric under the hood.
Also just quoting the bit I edited in after in case you missed it (cause I was still editing when you replied):
Varnish does exactly that. It generates static files from wordpress. Which is great I think.
But you wouldn’t need host mode if you use the right names to connect.
Have you tried this from Varnish?
backend default {
    .host = "caddy";
    .port = "80";
Yes. I did. And it works if I connect to the varnish listening port :8090
But when I further configure reverse_proxy in Caddyfile to manage ssl it does not work. I receive too many redirects message. I can not understand why.
But when I do the same when Caddy and Varnish on one localhost network - it works.
Try using curl -vL <url> to make the request, see what it looks like. It’ll show you what redirects are being attempted.
Thank you! I did not know that. I will try to debug.
I did the cahnges you usggested and edited the initial post. With this settings I can access website using both HTTP and HTTPS, so I tried redirect directive, but if I apply it I get redirection error.
My Caddyfile:
https://viktorli.hopto.org {
http://viktorli.hopto.org  {
  redir https://viktorli.hopto.org
        root * /var/www/html
        @cachedFiles {
curl -vL --max-redirs 5 https://viktorli.hopto.org gives me:
* Connected to viktorli.hopto.org (46.109.12.149) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
*   CAfile: none
  CApath: /etc/ssl/certs
* SSL connection using TLSv1.3 / TLS_CHACHA20_POLY1305_SHA256
*  subject: CN=viktorli.hopto.org
*  start date: Dec  7 19:51:03 2020 GMT
*  expire date: Mar  7 19:51:03 2021 GMT
*  subjectAltName: host "viktorli.hopto.org" matched cert's "viktorli.hopto.org"
* Using Stream ID: 1 (easy handle 0x1911880)
> GET / HTTP/2
> Host: viktorli.hopto.org
> User-Agent: curl/7.64.0
< HTTP/2 302
< age: 0
< date: Wed, 09 Dec 2020 12:31:33 GMT
< location: https://viktorli.hopto.org
< server: Caddy
< server: Caddy
< via: 1.1 varnish (Varnish/5.0)
< x-varnish: 2
< content-length: 0
* Connection #0 to host viktorli.hopto.org left intact
* Issue another request to this URL: 'https://viktorli.hopto.org/'
* Found bundle for host viktorli.hopto.org: 0x1915250 [can multiplex]
* Re-using existing connection! (#0) with host viktorli.hopto.org
* Using Stream ID: 3 (easy handle 0x1911880)
> GET / HTTP/2
< HTTP/2 302
< age: 0
< server: Caddy
< server: Caddy
< x-varnish: 4
< content-length: 0
* Using Stream ID: 5 (easy handle 0x1911880)
> GET / HTTP/2
If I comment out the redirect block:
#http://viktorli.hopto.org  {
# redir https://viktorli.hopto.org
Everything works well.
If I use curl -vL --max-redirs 5 https://viktorli.hopto.org it gives me:
* ALPN, offering h2
*   CAfile: none
* Using Stream ID: 1 (easy handle 0x693880)
> GET / HTTP/2
< HTTP/2 200
< accept-ranges: bytes
< age: 0
< content-type: text/html; charset=UTF-8
< date: Wed, 09 Dec 2020 12:36:26 GMT
< link: <https://viktorli.hopto.org/wp-json/>; rel="https://api.w.org/"
< server: Caddy
< server: Caddy
< vary: Accept-Encoding
< x-powered-by: PHP/7.4.13
< x-varnish: 2
Why the redirect is not working?
I also tried changing Caddyfile to:
  redir https://{host}{uri} permanent
        @cachedFiles {
But it does not work aswell.
Also tried just the domain name without http or https in front:
        @cachedFiles {
Did not help either
UPD
Got the mistake.
I also have :80 directive which is causing the problem.
Edited the initial post
Well the problem is you’re having Varnish make the request on port 80, but you also turn on a redirect on port 80 (http:// is port 80). You can’t do that, that’s in conflict.
Instead, I recommend serving your wordpress backend on a different port like 8080 or something, and have Varnish hit that. That way, you won’t need to worry about the redirect being overriden because it wouldn’t be.
Just change :80 in your Caddyfile to :8080, then in your Varnish config change .port = "80"; to .port = "8080"; and you should be good to go.
Port 8080 would only be accessible to docker services only, not to the outside world. That way you’re ensuring that outside services can’t just skip past HTTPS by making HTTP requests.
