Caddy v2 - Reusable snippets
v2.0.0-beta12 h1:LZnXOGDr1SbeJNyln8Xc/hXjWCa/a9qFpCbWt2iwJPw=
MacOS 10.15.1
KUEUI_BASIC_AUTH_USERNAME=$(echo "user" | base64) KUEUI_BASIC_AUTH_PASSWORD=$(echo "pass" | base64) TARGET_ENV=local ./caddy adapt --config ./static/root/etc/Caddyfile --pretty
N/A
d. My complete Caddyfile:
I’ve just started converting to Caddy v2 format so it’s more v1 than v2 at the moment.
# TLS for local.
(tls-local) {
    tls {env.ACME_CA_EMAIL} {
        # ca https://acme-staging-v02.api.letsencrypt.org/directory
        dns route53
# TLS for everything else.
(tls-majority) {
        dns route53
    header / Strict-Transport-Security max-age=31536000
(tls-beta) {
    import tls-majority
(tls-production) {
    import tls-majority
{env.APP_DOMAIN} {
    log stdout {
        except /_status/ping
    log stderr {
    gzip
    import tls-{env.TARGET_ENV}
    root /www
    header / {
        Content-Security-Policy "frame-ancestors 'none'"
        X-Frame-Options "DENY"
    proxy / app:4000 {
        except /css /fonts /images /js /favicon.ico /robots.txt /default.html
import /etc/caddy/*.conf
It would seem as though Caddy v2 doesn’t yet support imports?
adapt: Caddyfile:40 - Error during parsing: File to import not found: tls-{env.TARGET_ENV}
I’ve confirmed that the environment variable is available to Caddy via KUEUI_BASIC_AUTH_USERNAME=$(echo "user" | base64) KUEUI_BASIC_AUTH_PASSWORD=$(echo "pass" | base64) TARGET_ENV=local ./caddy environ | grep TARGET_ENV and the output is TARGET_ENV=local as expected.
https://caddyserver.com/v1/docs/caddyfile#snippets
I can’t find any documentation about the import directive at GitHub - caddyserver/caddy: Fast and extensible multi-platform HTTP/1-2-3 web server with automatic HTTPS · GitHub or json — Caddy Documentation.
I did note that reusable snippets was mentioned here… V2 - adapt `unrecognized directive: proxy` - moving from Caddy v1
Hmm, I don’t know that you will be able to use environment variables for importing in v2. We’re trying to take env variable logic out of the Caddyfile parser, because they are evaluated when modules are loaded, deeper in the system.
Does the import work if you hard-code it?
So this fails with adapt: Caddyfile:22 - Error during parsing: File to import not found: tls-{env.TARGET_ENV}.
(tls-local) {
        protocols tls1.3 tls1.3
example.com {
    matcher all {
        path /
    matcher all-excluding-local-files {
        path /
        not {
            path /css /fonts /images /js /favicon.ico /robots.txt /default.html
    encode match:all {
        gzip
    headers match:all {
        Strict-Transport-Security "max-age=31536000"
    reverse_proxy match:all-excluding-local-files app:4000 {
        header_up Host {host}
        header_up X-Real-IP {remote}
        header_up X-Forwarded-For {remote}
        header_up X-Forwarded-Port {server-port}
    file_server * {
        root /www
But this works…
(tls-local) {
example.com {
    matcher all {
        path /
        path /
        not {
    import tls-local
    encode match:all {
        gzip
    headers match:all {
    file_server * {
        root /www
So I guess this answer is yes, it works when hard-coded. Sounds like it’s going to stay this way too?
Also, I just wanted to note here (I assume you’re already aware though) that:
(tls-local) {
example.com {
    import tls-local
works, but fails when you update the tls directive to:
    dns route53
Not necessarily, since we’re still in beta it’s easier to take feedback like this. We might be able to make it work, for imports specifically: https://github.com/caddyserver/caddy/pull/2963#issuecomment-571843648 – but not making any promises right now.
I think that’s expected, yes; the dns subdirective isn’t implemented, so I wouldn’t expect it to work (yet).
I think you can remove the extra tls1.3 too, unless I’m forgetting something…
Okay, no worries.
While we’re on the topic of environment variables logic in the Caddfile parser, I thought I should bring this to your attention.
This works:
example.com {
    file_server * {
        root /www
But the following fails with adapt: server block 0, key 0 ({env.APP_DOMAIN}): determining listener address: parsing key: parse //{env.APP_DOMAIN}: invalid character "{" in host name when being executed with APP_DOMAIN=example.com ./caddy adapt --config ./static/root/etc/Caddyfile --pretty:
{env.APP_DOMAIN} {
    file_server * {
        root /www
Ah, fun… guess we’ll need to find a way to hopefully benefit from the Go standard library’s URL parser while allowing placeholders. Okay, added to my list…
If you’ve been following along, you’ll notice that we’re making it so that you can use {$ENV_VAR} syntax in the Caddyfile to be replaced before parsing even begins. That should probably meet your needs, I think.
This implies that {env.VAR}-style placeholders are still deferred until runtime to be evaluated.
So, this:
I am not sure we can get this to work. The Caddyfile needs to know something about the site: the port, the domain name, a path, something… but since {env.APP_DOMAIN} would only be evaluated at runtime (after the Caddyfile is adapted into JSON), the Caddyfile adapter won’t know how to structure the JSON, because it’s not sure what to make of the site address (it remains a placeholder!).
Now, in your case, you can just use {$APP_DOMAIN} and that will be replaced by the Caddyfile before tokenizing and parsing even begins, and so that should work, because in theory Caddy would have a value to work with. But using {env.APP_DOMAIN} would leave it clueless, so… I’m not sure we can get that to work.
Is that OK with you? (If not, do you have an alternative idea/solution?)
@matt, yeah, I’ve been following along!
I can see how the following will never work:
{env.APP_DOMAIN} {
    file_server ...
It will always generate an error similar to what I demonstrated as you mention, it needs to know something about site at adapt time.
I think there are two solutions. The first being as you mentioned, making sure APP_DOMAIN exists at adapt-time, in this scenario, the following should work:
{$APP_DOMAIN} {
    file_server ...
The other is the following:
https://{env.APP_DOMAIN} {
    file_server ...
I think that would work based on what I’ve seen in the PR on GitHub? It will give the Caddyfile adapter enough information to proceed:
  • port: 443 (implied by https).
  • domain: {env.APP_DOMAIN} that will be passed through into the JSON and then evaluated at runtime.
Is that correct?
To be clear, there already will be a solution, if you don’t mind the substitution happening at the time the Caddyfile is adapted: use {$APP_DOMAIN} instead of {env.APP_DOMAIN}.
However, if the runtime environment will be different and thus you have to use {env.APP_DOMAIN}, then yeah that won’t work.
However, if you can at least give it a hint:
That might be enough. Or {env.APP_DOMAIN}:1234 or example.com:{env.PORT} – I think these should all be able to work.
Given the alternative is landing probably tomorrow, do you really need this to work? I can add it to my list but the parsing logic to support this probably wouldn’t be simple, might take some time to figure out. (I’d rather not do it right now, unless there’s an actual and urgent need for it, if that’s alright.) Will the {$APP_DOMAIN} solution work for you?
@matt I can use {$APP_DOMAIN} for now, for sure :slight_smile: That will at least allow me to use v2 with Caddyfile.
Ultimately, at some point before v2, I think it would be awesome for Caddy if you did happen to include support for:
Okay. Good to know.
Does that mean you will eventually be adapting the Caddyfile in a different environment from the server?
Yes. Please refer to my use case as outlined here.
At start time, a Caddyfile in the static container will configure Caddy. At runtime (sometime later), a dynamically generated Caddyfile compiled in the supervisor container will update Caddy’s configuration in static via the Configuration API and the POST /load endpoint.
I should say, this will all be running in Kubernetes…
Okay, implemented in caddyfile: Less strict URL parsing; allows placeholders · caddyserver/caddy@8aef859 · GitHub.
The placeholder can only represent a single component of the possible address, however: scheme, host, port, or path.
