Caddy v2 middleware metrics not exposed
Somehow I am able to see admin metrics, runtime metics, reverse proxy metrics but not the middleware metrics. Until a few days ago the metrics were displayed just fine. I don´t know, what could have changed, except maybe for restarting caddy. I am calling the endpoint via http://localhost:2020/metrics. Any idea?
v2.6.2
Debian 11 5.10.0-21-amd64
; Ansible managed
; source: https://github.com/mholt/caddy/blob/master/dist/init/linux-systemd/caddy.service
; version: 6be0386
; changes: Set variables via Ansible
After=network-online.target
StartLimitIntervalSec=86400
StartLimitBurst=5
Restart=on-failure
User=www-data
Group=www-data
ExecStart="/usr/local/bin/caddy" run --environ --config "/etc/caddy/config.json"
ExecReload="/usr/local/bin/caddy" reload --config "/etc/caddy/config.json"
; Use a minimal /dev
PrivateDevices=true
ProtectHome=false
; … except /etc/ssl/caddy, because we want Letsencrypt-certificates there.
;   This merely retains r/w access rights, it does not add any new. Must still be writable on the host!
ReadWriteDirectories=/etc/ssl/caddy /var/log/caddy
; They further retrict privileges that can be gained by caddy.
NoNewPrivileges=true
  "apps": {
    "http": {
      "servers": {
        "metrics": {
          "listen":[":2020"],
          "routes":[
              "handle":[
                  "handler":"metrics"
        "apps": {...}
You need to enable metrics on the HTTP server as well. See apps/http/servers/metrics. You just need to set it to an empty object.
In an earlier version, Caddy always had metrics enabled, but we realized it caused some significant performance problems due to problems with the implementation so we just shifted it to being opt-in for the HTTP app, since we don’t have the expertise to maintain the metrics code right now, unfortunately.
