v2.0.0 and v2.1.0-beta
N/A
systemd on Ubuntu 18.04 with caddy run
I have redacted the domain name as I do not want these forum posts showing up in searches for my client’s domain.
misspelled.com {
redir https://example.com{uri} permanent
staging.example.com {
redir https://beta.example.com{uri} permanent
beta.example.com {
output stdout
format console
encode gzip zstd
reverse_proxy /api/* localhost:3001
@notApi {
file {
try_files {path} {path}/ /index.html
not path /api/*
route {
rewrite @notApi {http.matchers.file.relative}
root * /home/me/example.com/build/
I’d like to exclude encode gzip zstd
from a certain webhook path.
This is because either there is a bug in Caddy v2 and it is sending an improper type of gzip or zstd, or there is a bug in the webhook service (pandadoc) by which it is requesting compression, but not understanding the mutually selected compression.
I’ll be checking logs to try to find out which were the request and response headers in hopes of determining which encoding was selected, and if flipping the preferred order (i.e. encode zstd gzip
instead of encode gzip zstd
) makes a difference.
(will post back when I’ve found and captured these)
I’ve tested with curl --compress
and I seem to get the results I expect, which leads me to believe that it is not an issue with Caddy.
For now I’ve just removed encode gzip zstd
entirely.
N/A
