AlexSmith
(AlexSmith)
April 5, 2023, 2:21pm
1
Hello. Where I can find actually documentation about CORS settings for Caddy v2?
v2.6.4
docker
docker run -ti caddy:v2.6.4 caddy run --config /etc/caddy/Caddyfile
Use the header directive to set the response headers you need.
The specifics of CORS are out of scope of Caddy itself, you can read about the individual CORS headers on the MDN docs:
Cross-Origin Resource Sharing (CORS) is an HTTP-header based mechanism that allows a server to indicate any origins (domain, scheme, or port) other than its own from which a browser should permit loading resources. CORS also relies on a mechanism by...
AlexSmith
(AlexSmith)
April 5, 2023, 7:13pm
3
Do you have some best practice change header
Access-Control-Allow-Origin
Based on Host header? Article Setup CORS in Caddy 2 not actual for v2.64
You could do something like this:
(cors) {
@origin header Origin {args.0}
header @origin {
Access-Control-Allow-Origin "{args.0}"
Access-Control-Request-Method GET
origin1.com {
import cors origin1.com
origin2.com {
import cors origin2.com
AlexSmith
(AlexSmith)
April 6, 2023, 8:40am
5
How can I use IF for this block?
if ({http_origin} == "https://example.com") {
import cors https://example.com
if ({http_origin} == "https://example123.org") {
import cors https://example123.org
No. That’s not how Caddy works, there’s no if.
See the docs, you need to use request matchers and apply those to handlers.
