example.com {
basicauth /* {
redir https://a2.example.com
It seems that basicauth is not valid for redir.
example.com {
basicauth /* {
What you’re running into is due to the default directive order in Caddy:
You’ll notice that redir
is higher on the list than basicauth
To do what you want, the best way to fix it is to wrap those directives with a route
which lets you override the order in which directives within it will be handled.
example.com {
route {
basicauth {
Next time, please fill out the thread template. It’s important for us to help you.
