1. Output of caddy version:
macOS Monterey
version 12.6
Caddy was installed using brew:
- Homebrew 3.6.13-32-g93660d3
- Homebrew/homebrew-core (git revision 4207c8f65b1; last commit 2022-12-03)
- Homebrew/homebrew-cask (git revision ded31a6855; last commit 2022-12-03)
Not using "Docker/systemd/Kubernetes/make etc."
localhost:3000 {
encode zstd gzip
php_fastcgi 127.0.0.1:9000
header * {
-server
I am serving a local project using a Caddyfile and the entry point is an index.php.
Yesterday (02/12/2022) when running caddy run the project was served correctly.
Today I have updated Caddy to the latest version (v2.6.2 h1:wKoFIxpmOJLGl3QXoo6PNbYvGW4xLEgo32GPBEjWL8o=) and when I run caddy run and try to load the page https://localhost:3000 I am getting the message “No input file specified.”
$ curl -v https://localhost:3000 > curl_result.txt
* Trying 127.0.0.1:3000...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0* Connected to localhost (127.0.0.1) port 3000 (#0)
* ALPN: offers h2
* ALPN: offers http/1.1
} [5 bytes data]
} [512 bytes data]
{ [122 bytes data]
{ [15 bytes data]
{ [927 bytes data]
{ [78 bytes data]
{ [36 bytes data]
} [1 bytes data]
} [36 bytes data]
* ALPN: server accepted h2
* subject: [NONE]
* start date: Dec 3 07:52:52 2022 GMT
* expire date: Dec 3 19:52:52 2022 GMT
* subjectAltName: host "localhost" matched cert's "localhost"
* issuer: CN=Caddy Local Authority - ECC Intermediate
* SSL certificate verify ok.
} [5 bytes data]
* h2h3 [:method: GET]
* h2h3 [:path: /]
* h2h3 [:scheme: https]
* h2h3 [:authority: localhost:3000]
* h2h3 [user-agent: curl/7.86.0]
* h2h3 [accept: */*]
* Using Stream ID: 1 (easy handle 0x7f9743812400)
} [5 bytes data]
> GET / HTTP/2
> Host: localhost:3000
> accept: */*
{ [5 bytes data]
{ [130 bytes data]
} [5 bytes data]
< HTTP/2 404
< alt-svc: h3=":3000"; ma=2592000
< content-type: text/html; charset=UTF-8
< status: 404 Not Found
< x-powered-by: PHP/8.1.11
< content-length: 25
< date: Sat, 03 Dec 2022 14:01:42 GMT
{ [5 bytes data]
100 25 100 25 0 0 843 0 --:--:-- --:--:-- --:--:-- 1000
$ cat curl_result.txt
I am a Caddy newbie and I am testing to use Caddy for local development because to use the “https”.
The only topic I found was PHP : No input file specified but no solution.
I tried to search the documention but couldn’t find any solution or answer.
None.
Thank you
