Caddy v2.10.0 failing to render {remote_ip} placeholder, causing 400 errors (previously saw "module not registered")
Hello Caddy Community,
I’m running into a persistent and unusual issue with my Caddy reverse proxy setup on a Raspberry Pi, and I’m hoping to get some assistance diagnosing it.
My goal is to reverse proxy several services running on my local network using Caddy with automatic HTTPS via my DuckDNS domain. While some services are working correctly with HTTPS, I’m consistently getting “400: Bad Request” errors when trying to access Home Assistant and Portainer through Caddy.
Based on troubleshooting, the core problem seems to be that Caddy is failing to correctly render the {remote_ip} placeholder in the X-Forwarded-For header it sends to backend services.
My OS: Linux raspberrypi 6.12.25+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.25-1+rpt1 (2025-04-30) aarch64 GNU/Linux
Caddy Ver: 2.10.0
Install method: Installed via the official Caddy apt repository
My Complete Caddyfile:
        # Global options block
        email [PLEASE REPLACE WITH YOUR ACTUAL EMAIL ADDRESS]
        # debug # Uncomment if requested by community members
immich.defanouxpi.duckdns.org {
        reverse_proxy 192.168.50.143:2283
                output file /var/log/caddy/immich.log
nextcloud.defanouxpi.duckdns.org {
        reverse_proxy 192.168.50.143:8081
                X-Forwarded-Proto https
                Strict-Transport-Security "max-age=15552000; includeSubDomains"
                output file /var/log/caddy/nextcloud.log
homepage.defanouxpi.duckdns.org {
        reverse_proxy 192.168.50.143:3000
                output file /var/log/caddy/homepage.log
vaultwarden.defanouxpi.duckdns.org {
        reverse_proxy 192.168.50.143:11001
                output file /var/log/caddy/vaultwarden.log
pihole.defanouxpi.duckdns.org {
        reverse_proxy 192.168.50.143:81
                output file /var/log/caddy/pihole.log
glances.defanouxpi.duckdns.org {
        reverse_proxy 192.168.50.143:61208
                output file /var/log/caddy/glances.log
homeassistant.defanouxpi.duckdns.org {
        reverse_proxy 192.168.50.143:8123 {
                header_up Host {host}
                header_up X-Real-IP {remote_ip}
                header_up X-Forwarded-For {remote_ip}
                header_up Upgrade {header.Upgrade}
                header_up Connection {header.Connection}
                output file /var/log/caddy/homeassistant.log
portainer.defanouxpi.duckdns.org {
        reverse_proxy https://192.168.50.143:9443 {
                transport tls {
                        insecure_skip_verify # Temporary for testing
                output file /var/log/caddy/portainer.log
A snippet of my configuration.yaml for home assistant
http:
  use_x_forwarded_for: true
  trusted_proxies:
    - 192.168.50.143 # The internal IP address of my Raspberry Pi running Caddy
    # ... potentially other IPs if needed ...
Nothing else was changed with portainer yet so any help would be nice with that
but the error i get when trying to access that is ERR_SSL_PROTOCOL_ERROR
Please don’t ignore the template. It helps us. For instance, module not registered doesn’t make any sense in the context of your issue, and
The only thing I can tell you now, simply remove all of these
By default, Caddy passes through incoming headers—including Host—to the backend without modifications, with three exceptions:
