(Built from xCaddy)
Docker-compose OS: Pop!_OS 20.04 LTS
CMD ["/usr/bin/caddy", "run", "--config", "/etc/caddy/Caddyfile"]
Docker-compose.yaml looks like: (I’ve ommited applications non-related / interacting with caddy)
version: "2"
goautodial:
build:
context: ../goautodial
dockerfile: Dockerfile
image: caddy:2.1-custom
container_name: goautodial
- 80:80/tcp
- 443:443/tcp
- 2015:2015/tcp
- 2019:2019/tcp
- ../goautodial/config/caddy:/config/caddy
- ../goautodial/data:/data
- ../goautodial/php/sessions:/var/lib/php/sessions
- asterisk
- galera
kamailio:
image: kamailio/kamailio-ci:5.2-alpine
container_name: kamailio
depends_on:
- mariadb-galera-0
- asterisk
asterisk:
driver: bridge
galera:
driver: bridge
root * /var/www/html
php_fastcgi unix//run/php/php7.3-fpm.sock
TL;DR: ERR_CONNECTION_REFUSED at localhost
Initial context:
I’ve followed the quick-start, added a genericinfo.phpfile and the application GoAutodialv4 to/var/www/html -
Behaviour inside docker container:
curl localhost/info.phpworks fine with the expected php response; andcurl localhostgets me an application-related issue (Failed to read session data: user (path: /var/lib/php/sessions)) -
Behaviour outside docker container:
curl *docker-container-ip*/info.phpworks and gets the expected php response;
curl *docker-container-ip*gets the application-related issue;
Using a web browser to*docker-container-ip*/info.phpworks and gets the expected php webpage;
Using a web browser tohttp://*docker-container-ip*(root directory of application) gets redirected tohttps://*docker-container-ip*and fails withERR_CONNECTION_REFUSED
docker logs goautodial {"apps":{"http":{"servers":{"srv0":{"listen":[":80"],"routes":[{"handle":[{"handler":"vars","root":"/var/www/html"},{"encodings":{"gzip":{}},"handler":"encode"}]},{"match":[{"file":{"try_files":["{http.request.uri.path}/index.php"]},"not":[{"path":["*/"]}]}],"handle":[{"handler":"static_response","headers":{"Location":["{http.request.uri.path}/"]},"status_code":308}]},{"match":[{"file":{"try_files":["{http.request.uri.path}","{http.request.uri.path}/index.php","index.php"],"split_path":[".php"]}}],"handle":[{"handler":"rewrite","uri":"{http.matchers.file.relative}"}]},{"match":[{"path":["*.php"]}],"handle":[{"handler":"reverse_proxy","transport":{"protocol":"fastcgi","split_path":[".php"]},"upstreams":[{"dial":"unix//run/php/php7.3-fpm.sock"}]}]},{"handle":[{"handler":"file_server","hide":["/etc/caddy/Caddyfile"]}]}]}}}}} {"level":"info","ts":1594046137.9776142,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""} {"level":"info","ts":1594046137.983121,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["[::1]:2019","127.0.0.1:2019","localhost:2019"]} {"level":"info","ts":1594046137.9833162,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80} {"level":"info","ts":1594046137.9835515,"logger":"tls","msg":"cleaned up storage units"} {"level":"info","ts":1594046137.98387,"msg":"autosaved config","file":"/root/.config/caddy/autosave.json"} {"level":"info","ts":1594046137.9838767,"msg":"serving initial configuration"} 2020/07/06 14:35:37 [INFO][cache:0xc000213f20] Started certificate maintenance routine
- Changing global config to
debug, nothing else showed up, changinghttp_portandhttps_portto a higher one, but got same results.
