1. Caddy version (caddy version): 1
I run caddy on windows from a command line
Windows
Caddy -agree=true
UNITYHOME.ONLINE, http://192.168.1.126:2015 www.unityhome.online {
tls MY_EMAIL_ADDRESS
timeouts none
gzip
proxy /torrents/ http://192.168.1.104:9921/ {
without /torrents
websocket
proxy /security http://192.156.1.104:9925/Alexa/values/ {
without /security
websocket
# Optional security headers
header / {
-Server
Cache-Control "public, max-age=31536000"
Referrer-Policy "strict-origin"
X-Frame-Options "DENY"
errors {
404 /redir-target/NoSignal404.html
320 /redir-target/NoSignal404.html
402 /redir-target/NoSignal404.html
nobots "https://blog.haschek.at/tools/bomb.php" {
"Mozilla/5.0 (compatible; Googlebot/2.1; +http://www.google.com/bot.html)"
"Googlebot/2.1 (+http://www.google.com/bot.html)"
"Mozilla/5.0 (Linux; Android 6.0.1; Nexus 5X Build/MMB29P) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/41.0.2272.96 Mobile Safari/537.36 (compatible; Googlebot/2.1; +http://www.google.com/bot.html)"
"Googlebot-News"
"Googlebot-Image/1.0"
"Googlebot-Video/1.0"
"compatible; Mediapartners-Google/2.1; +http://www.google.com/bot.html"
"Mediapartners-Google"
"AdsBot-Google (+http://www.google.com/adsbot.html)"
"AdsBot-Google-Mobile-Apps"
"APIs-Google (+https://developers.google.com/webmasters/APIs-Google.html)"
regexp "Googlebot"
public "^/public"
public "^/[a-z]{,5}/public"
# Optional logging
log home.log
automation.unityhome.online http://192.168.1.126:2021 {
timeouts none
gzip
proxy / 192.168.1.15 {
without /automation
websocket
header / {
-Server
Access-Control-Allow-Origin "https://unityhome.online"
Access-Control-Allow-Methods "GET, POST, OPTIONS"
errors {
502 /redir-target/NoSignal404.html
401 /redir-target/NoSignal404.html
# Optional logging
basicauth / admin pass
camera.unityhome.online http://192.168.1.126:2028 {
timeouts none
gzip
proxy / 192.168.1.104:9925/Alexa/values {
websocket
header / {
-Server
errors {
# Optional logging
tor.unityhome.online http://192.168.1.126:2018 {
timeouts none
gzip
proxy / http://192.168.1.104:9921/ {
websocket
header / {
-Server
#Referrer-Policy "strict-origin"
errors {
# Optional logging
log tor.log
theater.unityhome.online http://192.168.1.126:2022 {
timeouts none
gzip
cors / {
origin *
origin *
methods GET
allowed_headers *
proxy / 192.168.1.126:8096 {
websocket
header / {
-Server
Access-Control-Allow-Origin *
errors {
"Googlebot-News"
regexp "Googlebot"
public "^/public"
# Optional logging
log theater.log
### 3. The problem I'm having:
Everything was working, and then yesterday I was unable to start the Caddy service. The command line says: "Activating privacy features", however, unlike most of the times I start the service, that is all it is doing.
### 4. Error messages and/or full log output:
<!-- Please **DO NOT REDACT** any information except credentials. Leave domain names intact! -->
<!-- Please **DO NOT POST TRUNCATED LOG LINES** as systemd is notorious for this. -->
<!-- Please **DO NOT USE WEB BROWSERS.** Use curl -v instead. -->
<!-- Please **DO ENABLE DEBUG MODE FIRST** by adding "debug" to the global options of your Caddyfile. -->
### 5. What I already tried:
<!-- Show us what effort you've put in to solving the problem. Be specific -- people are volunteering their time to help you! Low effort posts are not likely to get good answers! -->
I opened the ".caddy" folder, and renamed the following folders:
acme -> acme_bak
lock -> lock_bak
ocsp -> ocsp_bak
After renaming the folders, I ran Caddy again from command line, but this time there was an error:
"Failed to get certificate: acme : Error 400..."
"Timeout during connect (likely a fire wall problem"
I checked that both my windows firewall was allowing port 80 and 443.
I also check that my Network was allowing Let's Encrypt.
Next, I removed "_bak" from the folder names, and tried Caddy again.
It seems to be stuck on "Activating privacy features".
### 6. Links to relevant resources:
But I agree with the error message and your reply, it is likely a firewall or network config issue. The ACME CA couldn’t reach your Caddy instance.
