Caddy upgrade hidden in documentation
The caddy upgrade command made it a trivial exercise to upgrade to 2.4.3 for an earlier 2.4.x release.
I’ve noticed that it’s been documented under Subcommands, but appears to be missing in the summary view.under Command Line.
The subcommand build-info is also missing from this list.
Ah, thanks. If you want to fix it, you can write a PR on the GitHub - caddyserver/website: The Caddy website repo
Specifically it’s this file:
