Hey! I’m already using Caddy for quite some time as a LetsEncrypt-using reverse proxy for my public-facing website. Now, I also wanted to use it for my home network’s observability stack. Therefore, I configured the domain I use locally for my services (*.msanft.home) to use internal TLS (tls internal). However, as per the logs, Caddy still seems to try to obtain certificates from LetsEncrypt, which, due to the TLD, fails.
I wondered whether this is a precedence issue and tried adding the tls internal to all affected domains individually, but that didn’t help either.
I’m quite sure that this is a configuration issue on my side. What part am I missing here?
Jul 26 21:00:30 zeitgeist systemd[1]: Started Caddy.
Jul 26 21:00:31 zeitgeist caddy[183612]: {"level":"error","ts":1722027631.9028296,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"prometheus.msanft.home","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 400 urn:ietf:params:acme:error:rejectedIdentifier - Invalid identifiers requested :: Cannot issue for \"prometheus.msanft.home\": Domain name does not end with a valid public suffix (TLD)"}
Jul 26 21:00:31 zeitgeist caddy[183612]: {"level":"error","ts":1722027631.9046938,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"grafana.msanft.home","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 400 urn:ietf:params:acme:error:rejectedIdentifier - Invalid identifiers requested :: Cannot issue for \"grafana.msanft.home\": Domain name does not end with a valid public suffix (TLD)"}
Jul 26 21:00:31 zeitgeist caddy[183612]: {"level":"error","ts":1722027631.9082105,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"loki.msanft.home","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 400 urn:ietf:params:acme:error:rejectedIdentifier - Invalid identifiers requested :: Cannot issue for \"loki.msanft.home\": Domain name does not end with a valid public suffix (TLD)"}
Jul 26 21:00:32 zeitgeist caddy[183612]: {"level":"error","ts":1722027632.3889997,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"grafana.msanft.home","issuer":"acme.zerossl.com-v2-DV90","error":"[grafana.msanft.home] creating new order: attempt 1: https://acme.zerossl.com/v2/DV90/newOrder: HTTP 429: <html>\r\n<head><title>429 Too Many Requests</title></head>\r\n<body>\r\n<center><h1>429 Too Many Requests</h1></center>\r\n<hr><center>nginx</center>\r\n</body>\r\n</html>\r\n (ca=https://acme.zerossl.com/v2/DV90)"}
Jul 26 21:00:32 zeitgeist caddy[183612]: {"level":"error","ts":1722027632.389193,"logger":"tls.obtain","msg":"will retry","error":"[grafana.msanft.home] Obtain: [grafana.msanft.home] creating new order: attempt 1: https://acme.zerossl.com/v2/DV90/newOrder: HTTP 429: <html>\r\n<head><title>429 Too Many Requests</title></head>\r\n<body>\r\n<center><h1>429 Too Many Requests</h1></center>\r\n<hr><center>nginx</center>\r\n</body>\r\n</html>\r\n (ca=https://acme.zerossl.com/v2/DV90)","attempt":1,"retrying_in":60,"elapsed":1.470955232,"max_duration":2592000}
Jul 26 21:00:32 zeitgeist caddy[183612]: {"level":"error","ts":1722027632.6411288,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"loki.msanft.home","issuer":"acme.zerossl.com-v2-DV90","error":"HTTP 400 urn:ietf:params:acme:error:rejectedIdentifier - DNS identifier is invalid [loki.msanft.home]"}
Jul 26 21:00:32 zeitgeist caddy[183612]: {"level":"error","ts":1722027632.6412282,"logger":"tls.obtain","msg":"will retry","error":"[loki.msanft.home] Obtain: [loki.msanft.home] creating new order: attempt 1: https://acme.zerossl.com/v2/DV90/newOrder: HTTP 400 urn:ietf:params:acme:error:rejectedIdentifier - DNS identifier is invalid [loki.msanft.home] (ca=https://acme.zerossl.com/v2/DV90)","attempt":1,"retrying_in":60,"elapsed":1.723024814,"max_duration":2592000}
Jul 26 21:00:32 zeitgeist caddy[183612]: {"level":"error","ts":1722027632.6444054,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"prometheus.msanft.home","issuer":"acme.zerossl.com-v2-DV90","error":"HTTP 400 urn:ietf:params:acme:error:rejectedIdentifier - DNS identifier is invalid [prometheus.msanft.home]"}
Jul 26 21:00:32 zeitgeist caddy[183612]: {"level":"error","ts":1722027632.6445076,"logger":"tls.obtain","msg":"will retry","error":"[prometheus.msanft.home] Obtain: [prometheus.msanft.home] creating new order: attempt 1: https://acme.zerossl.com/v2/DV90/newOrder: HTTP 400 urn:ietf:params:acme:error:rejectedIdentifier - DNS identifier is invalid [prometheus.msanft.home] (ca=https://acme.zerossl.com/v2/DV90)","attempt":1,"retrying_in":60,"elapsed":1.726304095,"max_duration":2592000}
NixOS (systemd)
Linux zeitgeist 6.8.4 #1-NixOS SMP PREEMPT_DYNAMIC Thu Apr 4 18:25:06 UTC 2024 x86_64 GNU/Linux
systemd 255 (255.6)
caddy run --config /etc/caddy/caddy_config --adapter caddyfile
email certs@msanft.foo
level ERROR
*.msanft.home {
output file /var/log/caddy/access-*.msanft.home.log
tls internal
grafana.msanft.home {
output file /var/log/caddy/access-grafana.msanft.home.log
reverse_proxy localhost:3030
loki.msanft.home {
output file /var/log/caddy/access-loki.msanft.home.log
reverse_proxy localhost:3100
msanft.foo www.msanft.foo {
output file /var/log/caddy/access-msanft.foo.log
metrics
root * /nix/store/s32walvhg06gqy4d48m43fv9jzvahcxs-homepage
pad.msanft.foo {
output file /var/log/caddy/access-pad.msanft.foo.log
reverse_proxy localhost:3000
prometheus.msanft.home {
output file /var/log/caddy/access-prometheus.msanft.home.log
reverse_proxy localhost:9090
