Caddy: Too Many Redirects
Caddy v1.0.1-0.20190527141219-14a8ffedd8d4
caddy.service:
After=network-online.target
Restart=on-abnormal
User=root
Group=root
ExecStart=/usr/local/bin/caddy -agree -email email@redacted.com -http2 -log /opt/caddy/log -root /opt/caddy/webroot -conf /opt/caddy/Caddyfile
Environment="CLOUDFLARE_EMAIL=emailredacted"
Environment="CLOUDFLARE_API_KEY=keyredacted"
ExecReload=/bin/kill -USR1 $MAINPID
KillMode=mixed
KillSignal=SIGQUIT
LimitNPROC=64
NoNewPrivileges=true
Caddy is non-docker.
OS: Debian 9 64 Bit
NA
Wordpress Configuration
version: '3.3'
  db:
    image: mysql:5.7
    container_name: site-db
      - /srv/dev-disk-by-label-xdata/docker/site/db:/var/lib/mysql
    restart: always
      MYSQL_ROOT_PASSWORD: password1
      MYSQL_DATABASE: wpdb
      MYSQL_USER: wordpress
      MYSQL_PASSWORD: password
      caddynet:
        ipv4_address: 172.30.1.29
  wordpress:
    depends_on:
      - db
    container_name: site-wp
    image: wordpress:latest
      - "8409:80"
    restart: always
      WORDPRESS_DB_HOST: db:3306
      WORDPRESS_DB_USER: wordpress
      WORDPRESS_DB_PASSWORD: password
      WORDPRESS_DB_NAME: wpdb
      caddynet:
        ipv4_address: 172.30.1.28
  caddynet:
    external:
www.mydomain.com {
  root /gvault/webserver/site
test.mydomain.com {
  proxy / 172.30.1.28:80 {
    websocket
    dns cloudflare
When trying to navigate to test.mydomain.com, I get “Too many redirects”.
2020/02/18 14:04:23 [INFO] Serving http://test.mydomain.com
2020/02/18 14:04:55 [ERROR] failed to copy buffer:  read tcp 192.168.2.3:443->xx.9.41.xx:10956: use of closed network connection
2020/02/18 14:05:00 http: TLS handshake error from xx.63.162.xx:60225: no certificate available for 'mydomain.com'
2020/02/18 14:05:00 http: TLS handshake error from xx.63.162.xx:61697: no certificate available for 'mydomain.com'
2020/02/18 14:05:01 http: TLS handshake error from xx.63.162.xx:56673: read tcp 192.168.2.3:443->93.63.162.100:56673: read: connection reset by peer
2020/02/18 14:05:47 http: TLS handshake error from 192.168.2.1:56666: EOF
Cloudflare TLS is set to strict.
www subdomain works fine.
Navigating to the local IP address works just fine. The Wordpress container comes right up.
Hi @jiru443,
If Wordpress is fine locally via IP address, it’s probably expecting HTTP. Is Wordpress issuing a canonical/downgrade redirect based on the transparent preset’s X-Forwarded-Proto header?
You can try taking Wordpress out of the equation temporarily by serving a site with status 200 /. If that works, we know it’s a Wordpress issue.
You could also try taking Cloudflare’s reverse proxy off the table temporarily if it’s not a Wordpress issue.
P.S.: redacted.com and mydomain.com are both registered domains serving existing websites. We prefer you don’t redact anything - but if you must, instead of using someone else’s domain name, use the one that’s IANA-reserved specifically for this purpose: example.com.
In Caddy v1, the transparent preset the OP has in their configuration does those headers (and two others):
https://caddyserver.com/v1/docs/proxy#presets
