Hi
Totally new to Caddy, just after a bit of advise
I have been using Caddy to reverse proxy to my Jellyfin Server so I can access it remotely. This has been working well.
This is my simple caddyfile
MyDomain {
reverse_proxy localhost:8096
I would also like to remote access my NextPVR server and thought I might be able to do both with the same caddyfile
I tried this, thinking if I included the port I could access both applications. Jellyfin still works without having to type the port in the url but NextPVR returns “this site can’t be reached”
I then tried this
MyDomain:8096 {
MyDomain:8866 {
reverse_proxy localhost:8866
This actually stops my Jellyfin server from starting
I have Caddy, Jellyfin and NextPVR all on the same PC, is this good practice of should I have caddy on a separate PC?
Thanks
