Is it possible to reverse proxy to another caddy instance which in turn reverse proxies the request?
V2 from the latest dockerhub image
A caddy on a droplet configured to reverse to another caddy as follows:
https://gateway.host {
output stdout
level debug
reverse_proxy {
to https://service.host:28989
Caddy on another server configured as follows:
https://service.host:28989 {
output file /data/logs/service.log
level debug
reverse_proxy {
to http://localhost:1234
both servers are ubuntu linux dists, systemd and docker with the same docker compose.
caddy uses host networking and starts up correctly. Other configurations of caddy work flawlessly.
Reach the service running on service.host:1234 through gateway.host.
A browser returns a blank page with what looks like a status 200. It does show a curious message in the console which isn’t normally there:
The character encoding of the plain text document was not declared. The document will render with garbled text in some browser configurations if the document contains characters from outside the US-ASCII range. The character encoding of the file needs to be declared in the transfer protocol or file needs to use a byte order mark as an encoding signature.
Curl simply returns what looks like a message from Caddy:
* found 149 certificates in /etc/ssl/certs/ca-certificates.crt
* found 597 certificates in /etc/ssl/certs
* ALPN, offering http/1.1
* SSL connection using TLS1.2 / ECDHE_ECDSA_AES_256_GCM_SHA384
* server certificate verification OK
* server certificate status verification SKIPPED
* common name: service.host (matched)
* server certificate expiration date OK
* server certificate activation date OK
* certificate public key: EC
* certificate version: #3
* subject: CN=service.host
* start date: Sun, 29 Mar 2020 13:10:09 GMT
* expire date: Sat, 27 Jun 2020 13:10:09 GMT
* issuer: C=US,O=Let's Encrypt,CN=Let's Encrypt Authority X3
* compression: NULL
* ALPN, server accepted to use http/1.1
> GET / HTTP/1.1
> Host: sonarr.mjd.one
> User-Agent: curl/7.47.0
< HTTP/1.1 200 OK
< Content-Length: 0
< Date: Sun, 29 Mar 2020 17:28:25 GMT
< Server: Caddy
< Server: Caddy
If you are wondering why I’ve got two caddy instances it’s because the gateway accepts ipv4 (gateway.host) and the service.host only accepts ipv6. It’s essentially an ipv4 to ipv6 network bridge.
From the gateway caddy:
gateway-caddy | {
"level": "info",
"ts": 1585501669.1829925,
"logger": "http.log.access.log1",
"msg": "handled request",
"request": {
"method": "GET",
"uri": "/",
"proto": "HTTP/2.0",
"remote_addr": "xxxxxxxx:xxxx",
"host": "gateway.host",
"headers": {
"Te": [
"trailers"
"User-Agent": [
"Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:74.0) Gecko/20100101 Firefox/74.0"
"Accept": [
"text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8"
"Accept-Language": [
"en-GB,en;q=0.5"
"Accept-Encoding": [
"gzip, deflate, br"
"Dnt": [
"1"
"1"
"Cache-Control": [
"max-age=0"
"tls": {
"resumed": true,
"version": 772,
"ciphersuite": 4865,
"proto": "h2",
"proto_mutual": true,
"server_name": "gateway.host"
"common_log": "xxxxxxxxxxx - - [29/Mar/2020:17:07:49 +0000] \"GET / HTTP/2.0\" 200 0",
"latency": 0.031736535,
"size": 0,
"status": 200,
"resp_headers": {
"Date": [
"Sun, 29 Mar 2020 17:07:49 GMT"
"Server": [
"Caddy",
"Caddy"
"Content-Length": [
"0"
gateway-caddy | {
"level": "info",
"request": {
"method": "GET",
"uri": "/",
"headers": {
"gzip, deflate, br"
"Dnt": [
"1"
"1"
"Cache-Control": [
"max-age=0"
"Te": [
"trailers"
"User-Agent": [
"Accept": [
"en-GB,en;q=0.5"
"tls": {
"resumed": true,
"version": 772,
"proto": "h2",
"size": 0,
"status": 200,
"resp_headers": {
"Content-Length": [
"0"
"Date": [
"Server": [
"Caddy",
"Caddy"
Various directives, header experimentation - although I’m not entirely sure what I’m doing here so it’s more trial and error.
Interestingly, curl to https://service.host:28989 from the gateway machine absolutely fine, it returns the expected page data.
This seems to suggest access is fine and the caddy on service.host is handling the requests as expected. The gateway.host also works when reverse proxying to another service on service.host which is not behind the service.host caddy.
The service is http not https but this seems ok through a standard curl from gateway.host.
