Caddy tls configure problem
I want to use the email to register the certificate, can configure the maximum and minimum range of the encryption protocol version. Is there any way to achieve this?
Hi @faritor,
Set your email with the -email CLI flag:
https://caddyserver.com/docs/cli#email
Or per site with the tls directive:
https://caddyserver.com/docs/tls#syntax
Which also allows for configuration of the min/max protocol with the protocols subdirective:
https://caddyserver.com/docs/tls#protocols
No, you don’t understand. I want to use email to register the certificate and configure the encryption protocol version. I refer to the official website documentation, but I have not found a suitable solution.
    demo.mydomain.com {
        tls demo@domail.com {
               protocols tls1.0 tls1.2
this is wrong
Try both separately.
example.com {
  tls email@example.com
    protocols tls1.0 tls2.0
Solved my problem, thank you very much
