Caddy Timeouts-
I am trying to setup timeouts in my caddy configuration file (JSON format) and am not able to get my caddy file to validate.
I am using the documentation found here with little success: Caddy Timeout Documentation
I have a small simple caddy file called test.json to demonstrate the issue I am having:
    "apps": {
        "http": {
            "servers": {
                "timeouts": {
                    "idle":"30s",
                    "read_body":"10s",
                    "read_header": "15s",
                    "idle": "5m"
                "srv0": {
                    "listen": [":443"],
                    "routes": [
                            "match": [{
                                "host":["example.com"]
                            "handle": ["file_server"]
                    "automatic_https": {
                      "disable_redirects":true
The timeout section does not pass the caddy validation routine. Here is the command and error I get from the validation:
$ sudo caddy validate --config /etc/caddy/test.json
2025/04/07 17:11:12.239 INFO    using provided configuration    {"config_file": "/etc/caddy/test.json", "config_adapter": ""}
Error: loading http app module: decoding module config: http: json: unknown field "idle"
Here are my versions of Caddy/OS (Caddy is the only software I have installed and running on this server):
jim@caddyrevproxy:/etc/caddy$ caddy version
2.6.2
jim@caddyrevproxy:/etc/caddy$ uname -a
Linux caddyrevproxy 6.8.0-56-generic #58-Ubuntu SMP PREEMPT_DYNAMIC Fri Feb 14 15:33:28 UTC 2025 x86_64 x86_64 x86_64 GNU/Linux
Here are the commands I ran to install and get caddy running:
echo "deb [signed-by=/usr/share/keyrings/caddy-stable-archive-keyring.gpg] https://dl.cloudsmith.io/public/caddy/stable/deb/debian all main" | \
  sudo tee /etc/apt/sources.list.d/caddy-stable.list
sudo apt update
sudo apt install -y caddy
sudo systemctl enable caddy      # enable on boot
I have not gotten this far.   Bad config.
You seem to have idle listed twice, but are you maybe looking for these?
apps > http > servers > read_timeout
apps > http > servers > read_header_timeout
apps > http > servers > idle_timeout
That’s Caddyfile format, not JSON.
Also, just a heads-up that version 2.6.2 is getting pretty old.
