Caddy & Tailscale & Cloudflare (Certificate issue)
Hello, new here but thanks for your help in advance
I’m trying to setup caddy as a reverse proxy, via tailscale network with cloudflare CNAME redirection. But I’m having problems getting Caddy to accept my token to generate SSL certificate.
Following the steps at https://www.youtube.com/watch?v=Vt4PDUXB_fg,
Redacted part of the Cloudflare token. In the video the token did not have the cftu_ prefix. But this is what cloudflare is giving now, and full token was validate with curl for Zones and DNS
caddy      | {"level":"info","ts":1774076881.271653,"msg":"maxprocs: Leaving GOMAXPROCS=2: CPU quota undefined"}
caddy      | {"level":"info","ts":1774076881.271817,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":30076316467,"previous":9223372036854775807}
caddy      | {"level":"info","ts":1774076881.2726083,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
caddy      | {"level":"info","ts":1774076881.2738512,"msg":"adapted config to JSON","adapter":"caddyfile"}
caddy      | {"level":"warn","ts":1774076881.2739635,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":1}
caddy      | {"level":"info","ts":1774076881.2749794,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
caddy      | {"level":"info","ts":1774076881.2753055,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000015300"}
caddy      | {"level":"info","ts":1774076881.275449,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc000015300"}
caddy      | {"level":"info","ts":1774076881.2755399,"logger":"http","msg":"servers shutting down with eternal grace period"}
caddy      | {"level":"info","ts":1774076881.2756388,"msg":"maxprocs: No GOMAXPROCS change to reset"}
caddy      | Error: loading initial config: loading new config: loading http app module: provision http: getting tls app: loading tls app module: provision tls: provisioning automation policy 0: loading TLS automation management module: position 0: loading module 'acme': provision tls.issuance.acme: loading DNS provider module: loading module 'cloudflare': provision dns.providers.cloudflare: API token 'cfut_1bgW...0c' appears invalid; ensure it's correctly entered and not wrapped in braces nor quotes
can’t get the version as the container closes out because of invalid token message
dockerfile:
FROM caddy:builder AS builder
–mount=type=cache,target=/go/pkg/mod #    --mount=type=cache,target=/root/.cache/go-build \RUN xcaddy build \    --with     --with  #    --with github.com/hairyhenderson/caddy-teapot-module@v0.0.3-0
FROM caddy:latestCOPY --from=builder /usr/bin/caddy /usr/bin/caddy
Docker with Tailscale and Caddy
b. Command/Dockercompose:
  tailscale:
    image: tailscale/tailscale:latest
    container_name: tailscale
    hostname: caddy-node
    cap_add:
      - NET_ADMIN
      - SYS_MODULE
      - tailscale_state:/var/lib/tailscale
      - /dev/net/tun:/dev/net/tun
      - TS_AUTHKEY=${TS_AUTHKEY}
      - TS_STATE_DIR=/var/lib/tailscale
      - TS_PERMIT_CERT_UID=0
    network_mode: host
    image: ghcr.io/caddy-dns/cloudflare:latest
    cap_add:
      - NET_ADMIN
      - 443:443
      - /mnt/homelab/dockercompose/caddy/Caddyfile:/etc/caddy/Caddyfile
      - caddy_data:/data
      - caddy_config:/config
      - /var/run/tailscale:/var/run/tailscale:ro
      - CF_API_TOKEN=cfut_1bgW....820c
    depends_on:
      - tailscale
      - proxy
  caddy_data: null
  caddy_config: null
  tailscale_state: null
  proxy:
    driver: bridge
setup works with tls internal (commented out), but fails for cloudflare
(cloudflare) {
    dns cloudflare {env.CF_API_TOKEN}
# immich
photos.houseofinfinity.net {
  reverse_proxy 192.168.100.40:2283
  import cloudflare
  #tls internal
Possibly similar issue to Caddy & Tailscale & Cloudflare, Oh my! (certificate issue)
I too am having this same issue.
Error: loading initial config: loading new config: loading http app module: provision http: getting tls app: loading tls app module: provision tls: provisioning automation policy 0: loading TLS automation management module: position 0: loading module ‘acme’: provision tls.issuance.acme: loading DNS provider module: loading module ‘cloudflare’: provision dns.providers.cloudflare: API token ‘cfat_AC…6’ appears invalid; ensure it’s correctly entered and not wrapped in braces nor quotes
I tried CNAMEs and A records. Also tried switching to traefik, there it showed that it was trying to set caddy-node.tailf4b92.ts.net domain ( clearly not going to work as that was within my tailnet).
@senhorb The issue from your logs is the Cloudflare API key format. Likewise, this is my issue as well.
@nz_monkey I’m hopping it is. As I see it there are a couple of possibilities from least likely to most likely:
  1. No-one else is using caddy/cloudflare/tailscale at the moment, and there is an open issue. Highly unlikely
  2. The token format changed, and caddy/underlining library are having trouble. Unlikely as I don’t see them creating such a breaking change. Only suspicious as even the docs have to old format were it doesnt start with cfut_...
  3. I’m doing something wrong when entering the token, or with the setup of API options
This is what I have on cloudflare domains:
And the token options:
If I test the token per CF recommendations, it seems to be valid:
arthur@pop-os:~$ curl "https://api.cloudflare.com/client/v4/user/tokens/verify" \
-H "Authorization: Bearer cfut_6redacted3"
{"result":{"id":"55redacteda","status":"active"},"success":true,"errors":[],"messages":[{"code":10000,"message":"This API Token is valid and active","type":null}]}
So I’m at a lost. Everything but the SSL works, and I like the format of the Caddyfile
I’m picking that the token format has changed….
It was the token format change!
Created a patch at Update token regex by arthurbenemann · Pull Request #131 · caddy-dns/cloudflare · GitHub. But in the meantime it’s working with the following dockerfile:
RUN xcaddy build \
    --with github.com/caddy-dns/cloudflare=github.com/arthurbenemann/cloudflare@token-length
FROM caddy:latest
and compose:
  tailscale:
    cap_add:
      - NET_ADMIN
      - SYS_MODULE
      - TS_AUTHKEY=tskey-auth-redacted
    network_mode: host
    build: .
    depends_on:
      - tailscale
    cap_add:
      - NET_ADMIN
    network_mode: service:tailscale   # ← joins tailscale's host network
      - caddy_data:/data
      - /var/run/tailscale/tailscaled.sock:/var/run/tailscale/tailscaled.sock:ro
    # no ports: — not compatible with network_mode
      - CF_API_TOKEN=cfut_redacted
  whoami:
    image: traefik/whoami
    container_name: whoami
  caddy_data:
  caddy_config:
  tailscale_state:
Thanks. I applied the patch and everything is working perfectly now.
