I have been self-hosting my password manager (vaultwarden and caddy) for over 3 months. The pair had been running gracefully until last week when I suddenly cannot connect to vaultwarden anymore after a system restart. Upon further investigation I can see that caddy "could not get certificate from issuer” on startup. I cannot recall any change to the *.yml and the whole setup, except updating ubuntu.
I am not sure which one is running. Following the instruction from vaultwarden, I downloaded a copy of custom built caddy server for duckdns. But at the same time, I put “caddy:latest” In my docker-compose.yml. So which executable is actually being run?
docker-compose
NAME="Ubuntu"
VERSION="20.04.3 LTS (Focal Fossa)"
PRETTY_NAME="Ubuntu 20.04.3 LTS"
VERSION_ID="20.04"
Docker version 20.10.10, build b485636
Docker-compose up
version: '3'
bitwarden:
image: vaultwarden/server:latest
container_name: bitwarden
restart: always
- TZ=America/Toronto
- EXTENDED_LOGGING=true
- ROCKET_PORT=8080
- WEBSOCKET_ENABLED=true # Enable WebSocket notifications.
- SIGNUPS_ALLOWED=false
- LOG_FILE=/bw/bitwarden.log
- ${HOME}/MyDocker/vaultwarden/:/bw
- ${HOME}/MyDocker/vaultwarden/data:/data
image: caddy:latest
restart: always
- 80:80 # Needed for the ACME HTTP-01 challenge.
- 443:443
- ${HOME}/MyDocker/caddy/caddy-duckdns:/usr/bin/caddy # Your custom build of Caddy.
- ${HOME}/MyDocker/caddy/Caddyfile:/etc/caddy/Caddyfile:ro
- ${HOME}/MyDocker/caddy/config:/config
- ${HOME}/MyDocker/caddy/data:/data
- ${HOME}/MyDocker/caddy:/caddy
- ACME_AGREE=true
- DOMAIN=95daap8.duckdns.org # Your domain.
- EMAIL=myEmail@gmail.com # The email address to use for ACME registration.
- DUCKDNS_TOKEN=<<<my-duckdns-tocken>>> # Your Duck DNS token.
- LOG_FILE=/caddy/access.log
bitwarden.{$DOMAIN} {
level INFO
output file {$LOG_FILE} {
roll_size 10MB
roll_keep 10
# Use the ACME DNS-01 challenge to get a cert for the configured domain.
dns duckdns {$DUCKDNS_TOKEN}
ca https://acme-staging-v02.api.letsencrypt.org/directory
reverse_proxy /notifications/hub bitwarden:3012
reverse_proxy bitwarden:8080
Vaultwarden no longer responds. If I hit up the url, I’ll get “connection has timed out”. Using the bitwarden Firefox extension, I cannot sync with the server.
Starting bitwarden ... done
Starting caddy ... done
Attaching to caddy, bitwarden
caddy | {"level":"info","ts":1636256028.4099035,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy | {"level":"warn","ts":1636256028.412603,"msg":"input is not formatted with 'caddy fmt'","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
caddy | {"level":"info","ts":1636256028.4146504,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
caddy | {"level":"info","ts":1636256028.4162095,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00037c000"}
caddy | {"level":"info","ts":1636256028.416628,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
caddy | {"level":"info","ts":1636256028.416657,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
caddy | {"level":"info","ts":1636256028.4174325,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
caddy | {"level":"info","ts":1636256028.417518,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["95daap8.duckdns.org"]}
caddy | {"level":"info","ts":1636256028.4183562,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
caddy | {"level":"info","ts":1636256028.4183762,"msg":"serving initial configuration"}
caddy | {"level":"info","ts":1636256028.4187615,"logger":"tls.obtain","msg":"acquiring lock","identifier":"95daap8.duckdns.org"}
caddy | {"level":"info","ts":1636256028.4187849,"logger":"tls","msg":"finished cleaning storage units"}
caddy | {"level":"info","ts":1636256028.487794,"logger":"tls.obtain","msg":"lock acquired","identifier":"95daap8.duckdns.org"}
caddy | {"level":"info","ts":1636256028.5119073,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["95daap8.duckdns.org"],"ca":"https://acme-staging-v02.api.letsencrypt.org/directory","account":""}
caddy | {"level":"info","ts":1636256028.5119457,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["95daap8.duckdns.org"],"ca":"https://acme-staging-v02.api.letsencrypt.org/directory","account":""}
bitwarden | /--------------------------------------------------------------------\
bitwarden | | Starting Vaultwarden |
bitwarden | | Version 1.23.0 |
bitwarden | |--------------------------------------------------------------------|
bitwarden | | This is an *unofficial* Bitwarden implementation, DO NOT use the |
bitwarden | | official channels to report bugs/features, regardless of client. |
bitwarden | | Send usage/configuration questions or feature requests to: |
bitwarden | | https://vaultwarden.discourse.group/ |
bitwarden | | Report suspected bugs/issues in the software itself at: |
bitwarden | | https://github.com/dani-garcia/vaultwarden/issues/new |
bitwarden | \--------------------------------------------------------------------/
bitwarden |
bitwarden | [INFO] No .env file found.
bitwarden |
bitwarden | [2021-11-06 23:33:48.604][start][INFO] Rocket has launched from http://0.0.0.0:8080
bitwarden | [2021-11-06 23:33:48.602][parity_ws][INFO] Listening for new connections on 0.0.0.0:3012.
caddy | {"level":"warn","ts":1636256038.523879,"logger":"tls.issuance.acme.acme_client","msg":"HTTP request failed; retrying","url":"https://acme-staging-v02.api.letsencrypt.org/directory","error":"performing request: Get \"https://acme-staging-v02.api.letsencrypt.org/directory\": dial tcp: lookup acme-staging-v02.api.letsencrypt.org on 127.0.0.11:53: read udp 127.0.0.1:48018->127.0.0.11:53: i/o timeout"}
caddy | {"level":"warn","ts":1636256048.7757137,"logger":"tls.issuance.acme.acme_client","msg":"HTTP request failed; retrying","url":"https://acme-staging-v02.api.letsencrypt.org/directory","error":"performing request: Get \"https://acme-staging-v02.api.letsencrypt.org/directory\": dial tcp: lookup acme-staging-v02.api.letsencrypt.org on 127.0.0.11:53: read udp 127.0.0.1:49970->127.0.0.11:53: i/o timeout"}
caddy | {"level":"warn","ts":1636256059.027217,"logger":"tls.issuance.acme.acme_client","msg":"HTTP request failed; retrying","url":"https://acme-staging-v02.api.letsencrypt.org/directory","error":"performing request: Get \"https://acme-staging-v02.api.letsencrypt.org/directory\": dial tcp: lookup acme-staging-v02.api.letsencrypt.org on 127.0.0.11:53: read udp 127.0.0.1:53588->127.0.0.11:53: i/o timeout"}
caddy | {"level":"error","ts":1636256059.0273416,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"95daap8.duckdns.org","issuer":"acme-staging-v02.api.letsencrypt.org-directory","error":"[95daap8.duckdns.org] creating new order: provisioning client: performing request: Get \"https://acme-staging-v02.api.letsencrypt.org/directory\": dial tcp: lookup acme-staging-v02.api.letsencrypt.org on 127.0.0.11:53: read udp 127.0.0.1:53588->127.0.0.11:53: i/o timeout (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
caddy | {"level":"error","ts":1636256059.0273826,"logger":"tls.obtain","msg":"will retry","error":"[95daap8.duckdns.org] Obtain: [95daap8.duckdns.org] creating new order: provisioning client: performing request: Get \"https://acme-staging-v02.api.letsencrypt.org/directory\": dial tcp: lookup acme-staging-v02.api.letsencrypt.org on 127.0.0.11:53: read udp 127.0.0.1:53588->127.0.0.11:53: i/o timeout (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":1,"retrying_in":60,"elapsed":30.53955218,"max_duration":2592000}
caddy | {"level":"warn","ts":1636256129.042533,"logger":"tls.issuance.acme.acme_client","msg":"HTTP request failed; retrying","url":"https://acme-staging-v02.api.letsencrypt.org/directory","error":"performing request: Get \"https://acme-staging-v02.api.letsencrypt.org/directory\": dial tcp: lookup acme-staging-v02.api.letsencrypt.org on 127.0.0.11:53: read udp 127.0.0.1:59699->127.0.0.11:53: i/o timeout"}
caddy | {"level":"warn","ts":1636256139.3001022,"logger":"tls.issuance.acme.acme_client","msg":"HTTP request failed; retrying","url":"https://acme-staging-v02.api.letsencrypt.org/directory","error":"performing request: Get \"https://acme-staging-v02.api.letsencrypt.org/directory\": dial tcp: lookup acme-staging-v02.api.letsencrypt.org on 127.0.0.11:53: read udp 127.0.0.1:51208->127.0.0.11:53: i/o timeout"}
Using https://portchecker.co/ I verified that port 443 is open but not port 80. I am guessing that somehow the redirection of http->https failed (due to the failure to get certificate?).
On my machine that runs docker if I do “https://localhost”, I will get:
Secure Connection Failed
Error code: SSL_ERROR_INTERNAL_ERROR_ALERT
I have verified that bitwarden is serving by the bitwarden container at port 8080 properly. If I “curl http://172.24.0.3:8080”, I will get the html for bitwarden main page.
<!doctype html><html><head>…
I did “curl -v 95daap8.duckdns.org” and this is the response:
* Trying 192.168.1.55:80...
* TCP_NODELAY set
* Connected to 95daap8.duckdns.org (192.168.1.55) port 80 (#0)
> GET / HTTP/1.1
> Host: 95daap8.duckdns.org
> User-Agent: curl/7.68.0
< Connection: close
< Location: https://95daap8.duckdns.org/
< Server: Caddy
< Date: Sun, 07 Nov 2021 04:08:30 GMT
< Content-Length: 0
* Closing connection 0
I also did “curl -v https://acme-staging-v02.api.letsencrypt.org/directory” and this is the response
* Trying 172.65.46.172:443...
* TCP_NODELAY set
* Connected to acme-staging-v02.api.letsencrypt.org (172.65.46.172) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
CApath: /etc/ssl/certs
* SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
* subject: CN=acme-staging.api.letsencrypt.org
* start date: Oct 17 04:58:17 2021 GMT
* expire date: Jan 15 04:58:16 2022 GMT
* subjectAltName: host "acme-staging-v02.api.letsencrypt.org" matched cert's "acme-staging-v02.api.letsencrypt.org"
* issuer: C=US; O=Let's Encrypt; CN=R3
* SSL certificate verify ok.
* Using Stream ID: 1 (easy handle 0x55d4ee567c80)
> GET /directory HTTP/2
> Host: acme-staging-v02.api.letsencrypt.org
> user-agent: curl/7.68.0
> accept: */*
* old SSL session ID is stale, removing
* Connection state changed (MAX_CONCURRENT_STREAMS == 128)!
< HTTP/2 200
< server: nginx
< date: Sun, 07 Nov 2021 04:10:39 GMT
< content-type: application/json
< content-length: 822
< cache-control: public, max-age=0, no-cache
< x-frame-options: DENY
< strict-transport-security: max-age=604800
"f-JdEK0g4Mo": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417",
"keyChange": "https://acme-staging-v02.api.letsencrypt.org/acme/key-change",
"meta": {
"caaIdentities": [
"letsencrypt.org"
"termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf",
"website": "https://letsencrypt.org/docs/staging-environment/"
"newAccount": "https://acme-staging-v02.api.letsencrypt.org/acme/new-acct",
"newNonce": "https://acme-staging-v02.api.letsencrypt.org/acme/new-nonce",
"newOrder": "https://acme-staging-v02.api.letsencrypt.org/acme/new-order",
"renewalInfo": "https://acme-staging-v02.api.letsencrypt.org/get/draft-aaron-ari/renewalInfo/",
"revokeCert": "https://acme-staging-v02.api.letsencrypt.org/acme/revoke-cert"
* Connection #0 to host acme-staging-v02.api.letsencrypt.org left intact
This really puzzle me because things were running perfect before last week for more than 3 months.
I don’t really want to revert to writing passwords on paper, so please, can some guru shed some light to help me.
