1. Output of caddy version
Ubuntu 22.04.1 LTS - 5.15.0-56-generic
caddy start
# caddy.service
# for your installation.
Type=notify
just-vibing.net {
root * /var/www/Vibing
7DTD.just-vibing.net {
reverse_proxy 10.0.0.81:27016
amp.just-vibing.net {
reverse_proxy 10.0.0.80:8080
ark.just-vibing.net {
reverse_proxy 10.0.0.81:27015
factorio.just-vibing.net {
reverse_proxy 10.0.0.81:34197
rust.just-vibing.net {
reverse_proxy 10.0.0.81:28015
valheim.just-vibing.net {
reverse_proxy 10.0.0.81:2457
After a few days, Caddy just stops serving any webpage at all. However, using curl -v shows that the web server is at least trying to serve the default “Caddy works!” webpage. Restarting caddy makes everything work again without error until it breaks again.
-- Boot 2a073e719fbc40ab84f7d3d171a92f72 --
Dec 12 05:00:29 webvm systemd[1]: Starting Caddy...
Dec 12 05:00:30 webvm caddy[814]: caddy.HomeDir=/var/lib/caddy
Dec 12 05:00:30 webvm caddy[814]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Dec 12 05:00:30 webvm caddy[814]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Dec 12 05:00:30 webvm caddy[814]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Dec 12 05:00:30 webvm caddy[814]: caddy.Version=v2.6.2 h1:wKoFIxpmOJLGl3QXoo6PNbYvGW4xLEgo32GPBEjWL8o=
Dec 12 05:00:30 webvm caddy[814]: runtime.GOOS=linux
Dec 12 05:00:30 webvm caddy[814]: runtime.GOARCH=amd64
Dec 12 05:00:30 webvm caddy[814]: runtime.Compiler=gc
Dec 12 05:00:30 webvm caddy[814]: runtime.NumCPU=2
Dec 12 05:00:30 webvm caddy[814]: runtime.GOMAXPROCS=2
Dec 12 05:00:30 webvm caddy[814]: runtime.Version=go1.19.4
Dec 12 05:00:30 webvm caddy[814]: os.Getwd=/
Dec 12 05:00:30 webvm caddy[814]: LANG=en_US.UTF-8
Dec 12 05:00:30 webvm caddy[814]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
Dec 12 05:00:30 webvm caddy[814]: NOTIFY_SOCKET=/run/systemd/notify
Dec 12 05:00:30 webvm caddy[814]: HOME=/var/lib/caddy
Dec 12 05:00:30 webvm caddy[814]: LOGNAME=caddy
Dec 12 05:00:30 webvm caddy[814]: USER=caddy
Dec 12 05:00:30 webvm caddy[814]: INVOCATION_ID=3d7f62f7fc5740818e632422734cd46d
Dec 12 05:00:30 webvm caddy[814]: JOURNAL_STREAM=8:22551
Dec 12 05:00:30 webvm caddy[814]: SYSTEMD_EXEC_PID=814
Dec 12 05:00:30 webvm caddy[814]: {"level":"info","ts":1670821230.4000623,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Dec 12 05:00:30 webvm caddy[814]: {"level":"info","ts":1670821230.4061868,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
Dec 12 05:00:30 webvm caddy[814]: {"level":"warn","ts":1670821230.4126754,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80}
Dec 12 05:00:30 webvm caddy[814]: {"level":"info","ts":1670821230.4133155,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0003fba40"}
Dec 12 05:00:30 webvm caddy[814]: {"level":"info","ts":1670821230.4159014,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Dec 12 05:00:30 webvm caddy[814]: {"level":"info","ts":1670821230.4161127,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Dec 12 05:00:30 webvm caddy[814]: {"level":"info","ts":1670821230.417206,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Dec 12 05:00:30 webvm caddy[814]: {"level":"info","ts":1670821230.4173903,"msg":"serving initial configuration"}
Dec 12 05:00:30 webvm systemd[1]: Started Caddy.
Dec 12 05:00:30 webvm caddy[814]: {"level":"info","ts":1670821230.440295,"logger":"tls","msg":"finished cleaning storage units"}
Dec 13 05:00:30 webvm caddy[814]: {"level":"info","ts":1670907630.8956876,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Dec 13 05:00:30 webvm caddy[814]: {"level":"info","ts":1670907630.8968818,"logger":"tls","msg":"finished cleaning storage units"}
Dec 14 05:00:30 webvm caddy[814]: {"level":"info","ts":1670994030.956278,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Dec 14 05:00:30 webvm caddy[814]: {"level":"info","ts":1670994030.9573529,"logger":"tls","msg":"finished cleaning storage units"}
Dec 15 05:00:30 webvm caddy[814]: {"level":"info","ts":1671080430.895727,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Dec 15 05:00:30 webvm caddy[814]: {"level":"info","ts":1671080430.897098,"logger":"tls","msg":"finished cleaning storage units"}
Dec 16 05:00:30 webvm caddy[814]: {"level":"info","ts":1671166830.8956997,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Dec 16 05:00:30 webvm caddy[814]: {"level":"info","ts":1671166830.8967397,"logger":"tls","msg":"finished cleaning storage units"}
Dec 17 05:00:30 webvm caddy[814]: {"level":"info","ts":1671253230.8957176,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Dec 17 05:00:30 webvm caddy[814]: {"level":"info","ts":1671253230.8967993,"logger":"tls","msg":"finished cleaning storage units"}
Dec 18 05:00:30 webvm caddy[814]: {"level":"info","ts":1671339630.9532027,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Dec 18 05:00:30 webvm caddy[814]: {"level":"info","ts":1671339630.9543676,"logger":"tls","msg":"finished cleaning storage units"}
● caddy.service - Caddy
Loaded: loaded (/lib/systemd/system/caddy.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2022-12-12 05:00:30 UTC; 6 days ago
Main PID: 814 (caddy)
Tasks: 9 (limit: 4574)
Memory: 46.0M
CPU: 12.883s
└─814 /usr/bin/caddy run --environ --config /etc/caddy/Caddyfile
Dec 18 06:59:45 webvm caddy[814]: {"level":"info","ts":1671346785.029071,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Dec 18 06:59:45 webvm caddy[814]: {"level":"info","ts":1671346785.0295017,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0000eb7a0"}
Dec 18 06:59:45 webvm caddy[814]: {"level":"info","ts":1671346785.0295217,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/luca>
Dec 18 06:59:45 webvm caddy[814]: {"level":"info","ts":1671346785.029592,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Dec 18 06:59:45 webvm caddy[814]: {"level":"info","ts":1671346785.0296388,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Dec 18 06:59:45 webvm caddy[814]: {"level":"info","ts":1671346785.0296443,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["rust.just-vibing.net","amp.just-vibing.net","ark.jus>
Dec 18 06:59:45 webvm caddy[814]: {"level":"info","ts":1671346785.8089614,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0003fba40"}
Dec 18 06:59:45 webvm caddy[814]: {"level":"info","ts":1671346785.8090935,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Dec 18 06:59:45 webvm caddy[814]: {"level":"info","ts":1671346785.8094208,"logger":"admin.api","msg":"load complete"}
Dec 18 06:59:46 webvm caddy[814]: {"level":"info","ts":1671346786.093588,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
I’ve tried recreating my config file from scratch, purged and reinstalled caddy. I’ve also tried having it just serve the website (no reverse proxy) and it still eventually stops responding.
At the time of this post the VM has been restarted and so for now it works properly.
