I run several subdomains through reverse proxy and Caddy. At some point my SSL certificates stopped being renewed and expired. Reading through the logs, it seems like it’s failing to renew through ZeroSSL. Any help decoding the error messages is greatly appreciated!
p.s. when using reverse_proxy, is it necessary to include http://?
I’ve pulled error messages for just one of the sub-domains (I think I got it all) since the logs are the same for the various subdomains and too large to copy & paste into the topic. The complete logs are here.
{"level":"info","ts":1695153826.9741719,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["sonarr.greghao.com","radarr.greghao.com","trans.greghao.com","tautulli.greghao.com","jackett.greghao.com","www.greghao.com","sabnzbd.greghao.com","adguard.greghao.com","overseerr.greghao.com"]}
{"level":"warn","ts":1695153827.053664,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [radarr.greghao.com]: parsing OCSP response: ocsp: error from server: unauthorized","identifiers":["radarr.greghao.com"]}
{"level":"info","ts":1695153827.0541282,"logger":"tls.renew","msg":"acquiring lock","identifier":"radarr.greghao.com"}
{"level":"info","ts":1695153827.057894,"logger":"tls.renew","msg":"lock acquired","identifier":"radarr.greghao.com"}
{"level":"info","ts":1695153827.0585961,"logger":"tls.renew","msg":"renewing certificate","identifier":"radarr.greghao.com","remaining":-99803.058595}
{"level":"info","ts":1695153827.6519349,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"radarr.greghao.com","challenge_type":"http-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
{"level":"error","ts":1695153858.954658,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"radarr.greghao.com","challenge_type":"http-01","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"2606:4700:3036::ac43:d0c9: Invalid response from http://radarr.greghao.com/.well-known/acme-challenge/LlLSXxgUWCqyeGTgw1XRz1rdYYg3KboPI0-ZtkTkScU: 522","instance":"","subproblems":[]}}
{"level":"error","ts":1695153858.9547222,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"radarr.greghao.com","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"2606:4700:3036::ac43:d0c9: Invalid response from http://radarr.greghao.com/.well-known/acme-challenge/LlLSXxgUWCqyeGTgw1XRz1rdYYg3KboPI0-ZtkTkScU: 522","instance":"","subproblems":[]},"order":"https://acme-v02.api.letsencrypt.org/acme/order/974460856/209505349976","attempt":1,"max_attempts":3}
V 2.7.4
brew install caddy
MacOS 13.5.2
brew services start caddy
email greg@twilightstar.net
(basic-auth) {
basicauth / {
1234 abcd
sabnzbd.greghao.com {
reverse_proxy http://127.0.0.1:8080
trans.greghao.com {
reverse_proxy http://127.0.0.1:9091
radarr.greghao.com {
import basic-auth
reverse_proxy http://127.0.0.1:9092
sonarr.greghao.com {
import basic-auth
reverse_proxy http://127.0.0.1:9093
tautulli.greghao.com {
reverse_proxy http://127.0.0.1:9094
www.greghao.com {
import basic-auth
reverse_proxy http://127.0.0.1:9095
jackett.greghao.com {
import basic-auth
reverse_proxy http://127.0.0.1:9096
overseerr.greghao.com {
reverse_proxy http://127.0.0.1:9097
adguard.greghao.com {
reverse_proxy http://192.168.10.52
