"Caddy Split-Horizon Conflict: Too Many Redirects with Cloudflare Tunnel on Port 80"
I am running a split-horizon reverse proxy setup in a single Caddy container for internal (LAN) and external (Cloudflare Tunnel) traffic.
  • Internal Access (LAN): Works perfectly over HTTPS. LAN clients use a local DNS record to resolve jf.mydom.com to Caddy’s container IP (192.168.4.99) on Port 443. Status 200.
  • External Access (Cloudflare Tunnel): Fails with a “Too Many Redirects” error. The Cloudflare Tunnel sends plain HTTP traffic to Caddy’s Port 80. Crucially, Caddy shows no log entries for these external requests, indicating the redirect loop is happening before Caddy successfully proxies the request, or the request is immediately hitting a non-existent implicit redirect.
Key Context: I have a separate, working dedicated Caddy instance for another domain (myotherdom.com) that only handles external Cloudflare Tunnel traffic on Port 80, and it works perfectly using the exact same proxy headers (X-Forwarded-Proto https). This confirms the issue is not with Cloudflare, the Tunnel, the backend apps (Jellyfin, Sonarr, Radarr), or the X-Forwarded-Proto header, but a conflict within the single split-horizon Caddyfile.
The Caddy logs show no entry for external access attempts, despite the level DEBUG setting. Caddy is simply not logging the request, yet the browser shows “Too Many Redirects.”
A log snippet for a working internal access attempt is provided for comparison.
{"level":"info","ts":1762661624.0417576,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"info","ts":1762661624.045819,"logger":"http.log","msg":"server running","name":"srv1","protocols":["h1","h2","h3"]}
{"level":"info","ts":1762661624.0460715,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
# --- LOG SNIPPET FOR WORKING INTERNAL (HTTPS, Port 443) ---
{"level":"debug","ts":1762660698.438884,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"192.168.4.60:8989","total_upstreams":1}
{"level":"debug","ts":1762660698.4394803,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"192.168.4.60:8989","duration":0.000546789,"request":{"remote_ip":"192.168.1.10","remote_port":"31098","client_ip":"192.168.1.10","proto":"HTTP/2.0","method":"GET","host":"sarr.mydom.com","uri":"/","headers":{"X-Forwarded-Host":["sarr.mydom.com"],"X-Forwarded-For":["192.168.1.10"],"X-Forwarded-Proto":["https"],"Via":["2.0 Caddy"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"sarr.mydom.com"}},"status":200}
v2.10.2
docker run -d
–name caddy
–network custom_bridge_network
-p 80:80
-p 443:443
-v /path/to/Caddyfile:/etc/caddy/Caddyfile
-v caddy_data:/data
caddy/caddy:latest
    email {$ACME_EMAIL}
    acme_dns cloudflare {$CLOUDFLARE_API_TOKEN}
    servers {
        trusted_proxies static 192.168.0.0/16
        level DEBUG
# Snippet for external Caddy (hardcoded HTTPS from Cloudflare Tunnel)
(proxy_headers_https) {
    header_up X-Forwarded-For {remote_host}
    header_up X-Forwarded-Proto https
# 1. EXTERNAL / TUNNEL BLOCK (HTTP / Port 80) - NO REDIRECTS
#    - This ONLY proxies traffic coming from the Cloudflare Tunnel.
    @jellyfin host jf.mydom.com
    handle @jellyfin {
        reverse_proxy 192.168.4.40:8096 {
            import proxy_headers_https
    @sonarr host sarr.mydom.com
    handle @sonarr {
        reverse_proxy 192.168.4.60:8989 {
    @radarr host rarr.mydom.com
    handle @radarr {
        reverse_proxy 192.168.4.62:7878 {
# 2. INTERNAL / LAN ACCESS BLOCK (HTTPS / Port 443)
#    - This handles LAN clients using HTTPS directly.
jf.mydom.com, sarr.mydom.com, rarr.mydom.com {
		resolvers 1.1.1.1, 8.8.8.8
    reverse_proxy @jellyfin 192.168.4.40:8096
    reverse_proxy @sonarr 192.168.4.60:8989
    reverse_proxy @radarr 192.168.4.62:7878
  • Cloudflare Trace shows the external client is requesting HTTPS (visit_scheme=https).
  • The Cloudflare Tunnel’s ingress for these hosts points to http://caddy_container_ip:80.
  • A previous Caddy log confirmed the Cloudflare Tunnel source IP is 192.168.4.8. Attempts to use a remote_ip 192.168.4.8/32 matcher also resulted in the redirect loop.
  • The backend applications are running on: 192.168.4.40, 192.168.4.60, and 192.168.4.62.
By default, Caddy redirects all HTTP traffic to HTTPS. So if Cloudflare is forwarding traffic to Caddy over HTTP, Caddy will try to redirect it to HTTPS, causing your browser to go to Cloudflare again, which then sends it back to Caddy over HTTP, and the cycle repeats. That’s what’s causing the redirect loop.
You’ve got two ways to fix it:
  1. Forward traffic from Cloudflare to Caddy using HTTPS, or
  2. Disable Caddy’s automatic HTTP-to-HTTPS redirects
Thanks. That sorted everything out.
I knew I’d feel like an idiot once I found it what it was.
