Caddy-snake v0.4.0: CGo removed, standalone binaries, 2-3x faster than standard reverse proxy setups
Continuing the discussion from Python plugin with support for WSGI:
Hey all, sharing a big update to caddy-snake!
A lot has changed since the original post. The biggest news in v0.4.0: CGo is completely gone. The WSGI/ASGI bridge has been rewritten in pure Python, communicating with Go over worker processes. This means no C compiler required at build or runtime, and a much simpler setup overall.
Other highlights:
  • Standalone app binaries (embed-app): package your Python app + Caddy + Python interpreter into a single self-contained executable, similar to FrankenPHP.
  • Benchmarks: Flask + caddy-snake hits 3,782 req/s vs 1,592 with Gunicorn+Caddy. FastAPI + caddy-snake hits 5,730 req/s vs 3,537 with Uvicorn+Caddy.
  • Go 1.26, minimum Python 3.12.
Full release notes: Release v0.4.0 · mliezun/caddy-snake · GitHub
Thanks for the kind reception back when this started.
Very cool!! Thanks for the great work, I shared it on a cursed social media site :slight_smile:
Thank you!
Very nice!
I’d be curious to see how it performs versus Caddy+Granian, as far as I understand that’s currently the go-to for performance. (I’m not a Python dev though, just sitting here on the sidelines)
I haven’t tested it yet, but I’d expect Caddy+Granian to be faster.
I’m focusing more on usability and ease of integration than raw performance, but I still want to make sure it’s fast enough so people aren’t worried about that.
