When I enter the ip address in the browser it says `This site can’t provide a secure connection`
v2.7.6
Ubuntu
servers {
metrics
cabincrewforyou.com {
root * /var/www/html
# php_fastcgi localhost:9000
94.130.26.101:80 {
root * /var/www/html2
I’m not using a domain because I don’t want to show the domain (the only one I have) to a potential client. I’d rather it be an ip address rather than the stupid domain name.
So you expect Caddy to be able to serve an ip address like this?
You can get more domains, e.g. free ones from DuckDNS or whatever. You’re not limited to only having one domain.
There’s no issue with serving from an IP host. You haven’t actually shown the evidence that it’s not working. Make a request with curl -v and show what you get.
I assumed i’d be able to reach the website through the IP address in the browser, and when I couldn’t, assumed that something was wrong with my Caddyfile.
When I curl my website curl https://cabincrewforyou.com, I get the index page for var/www/html, so I’d hope to see the index page for var/www/html2when I do curl 94.130.26.101:80 or curl http://94.130.26.101 but I get nothing.
When I do curl -v 94.130.26.101, I get
* Trying 94.130.26.101...
* TCP_NODELAY set
* Connected to 94.130.26.101 (94.130.26.101) port 80 (#0)
> GET / HTTP/1.1
> Host: 94.130.26.101
> User-Agent: curl/7.64.1
< Connection: close
< Location: https://94.130.26.101/
< Server: Caddy
< Date: Wed, 20 Mar 2024 17:31:14 GMT
< Content-Length: 0
* Closing connection 0
Is that what you’d expect to see? I have no idea if it’s “working”.
Are you sure you reloaded Caddy after changing your config?
That behaviour from curl -v shows that Caddy responded with a redirect to HTTPS after seeing your request, which is the default behaviour when there’s no site.
