OS: Ubuntu 18.04.4 LTS
Running with SystemD.
systemctl start caddy
(see below for the service file)
# caddy.service
# for your installation.
After=network.target
User=www-data
Group=www-data
ExecStart=/usr/local/bin/caddy run --environ --config /etc/caddy/Caddyfile
ExecReload=/usr/local/bin/caddy reload --config /etc/caddy/Caddyfile
email [redacted]
matrix.club-tech.fr, matrix.club-tech.fr:8448 {
reverse_proxy /_matrix/* 127.0.0.1:8008
header Access-Control-Allow-Origin *
root * /srv/http/riot-v1.6.0
I’ve just updated to Caddy 2, and the HTTP-01 challenge seems to fail. Looking at the logs, it looks like it’s trying to use 127.0.0.1 as the address for it, which sounds bogus to me. It also seems to be trying and failing the ALPN-01 challenge but I don’t know if that’s related.
Jul 07 11:51:41 matrix-club-tech systemd[1]: Started Caddy.
Jul 07 11:51:41 matrix-club-tech caddy[30374]: caddy.HomeDir=/var/www
Jul 07 11:51:41 matrix-club-tech caddy[30374]: caddy.AppDataDir=/var/www/.local/share/caddy
Jul 07 11:51:41 matrix-club-tech caddy[30374]: caddy.AppConfigDir=/var/www/.config/caddy
Jul 07 11:51:41 matrix-club-tech caddy[30374]: caddy.ConfigAutosavePath=/var/www/.config/caddy/autosave.json
Jul 07 11:51:41 matrix-club-tech caddy[30374]: runtime.GOOS=linux
Jul 07 11:51:41 matrix-club-tech caddy[30374]: runtime.GOARCH=amd64
Jul 07 11:51:41 matrix-club-tech caddy[30374]: runtime.Compiler=gc
Jul 07 11:51:41 matrix-club-tech caddy[30374]: runtime.NumCPU=1
Jul 07 11:51:41 matrix-club-tech caddy[30374]: runtime.GOMAXPROCS=1
Jul 07 11:51:41 matrix-club-tech caddy[30374]: runtime.Version=go1.14.4
Jul 07 11:51:41 matrix-club-tech caddy[30374]: os.Getwd=/
Jul 07 11:51:41 matrix-club-tech caddy[30374]: LANG=C.UTF-8
Jul 07 11:51:41 matrix-club-tech caddy[30374]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
Jul 07 11:51:41 matrix-club-tech caddy[30374]: HOME=/var/www
Jul 07 11:51:41 matrix-club-tech caddy[30374]: LOGNAME=www-data
Jul 07 11:51:41 matrix-club-tech caddy[30374]: USER=www-data
Jul 07 11:51:41 matrix-club-tech caddy[30374]: INVOCATION_ID=cda4586cdb774ab18aeaef16ba14597f
Jul 07 11:51:41 matrix-club-tech caddy[30374]: JOURNAL_STREAM=9:1236885
Jul 07 11:51:41 matrix-club-tech caddy[30374]: {"level":"info","ts":1594122701.6306107,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Jul 07 11:51:41 matrix-club-tech caddy[30374]: {"level":"info","ts":1594122701.637606,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
Jul 07 11:51:41 matrix-club-tech caddy[30374]: {"level":"info","ts":1594122701.638253,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv1"}
Jul 07 11:51:41 matrix-club-tech caddy[30374]: {"level":"info","ts":1594122701.638481,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Jul 07 11:51:41 matrix-club-tech caddy[30374]: {"level":"info","ts":1594122701.6384995,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Jul 07 11:51:41 matrix-club-tech caddy[30374]: {"level":"info","ts":1594122701.6390934,"logger":"tls","msg":"cleaned up storage units"}
Jul 07 11:51:41 matrix-club-tech caddy[30374]: {"level":"info","ts":1594122701.6393309,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["matrix.club-tech.fr"]}
Jul 07 11:51:41 matrix-club-tech caddy[30374]: {"level":"info","ts":1594122701.6395383,"msg":"autosaved config","file":"/var/www/.config/caddy/autosave.json"}
Jul 07 11:51:41 matrix-club-tech caddy[30374]: {"level":"info","ts":1594122701.6395538,"msg":"serving initial configuration"}
Jul 07 11:51:41 matrix-club-tech caddy[30374]: 2020/07/07 11:51:41 [INFO][cache:0xc000247b00] Started certificate maintenance routine
Jul 07 11:51:41 matrix-club-tech caddy[30374]: 2020/07/07 11:51:41 [INFO][matrix.club-tech.fr] Obtain certificate; acquiring lock...
Jul 07 11:51:41 matrix-club-tech caddy[30374]: 2020/07/07 11:51:41 [INFO][matrix.club-tech.fr] Obtain: Lock acquired; proceeding...
Jul 07 11:51:42 matrix-club-tech caddy[30374]: 2020/07/07 11:51:42 [INFO][matrix.club-tech.fr] Waiting on rate limiter...
Jul 07 11:51:42 matrix-club-tech caddy[30374]: 2020/07/07 11:51:42 [INFO][matrix.club-tech.fr] Done waiting
Jul 07 11:51:42 matrix-club-tech caddy[30374]: 2020/07/07 11:51:42 [INFO] [matrix.club-tech.fr] acme: Obtaining bundled SAN certificate given a CSR
Jul 07 11:51:43 matrix-club-tech caddy[30374]: 2020/07/07 11:51:43 [INFO] [matrix.club-tech.fr] AuthURL: https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/73664028
Jul 07 11:51:43 matrix-club-tech caddy[30374]: 2020/07/07 11:51:43 [INFO] [matrix.club-tech.fr] acme: Could not find solver for: tls-alpn-01
Jul 07 11:51:43 matrix-club-tech caddy[30374]: 2020/07/07 11:51:43 [INFO] [matrix.club-tech.fr] acme: use http-01 solver
Jul 07 11:51:43 matrix-club-tech caddy[30374]: 2020/07/07 11:51:43 [INFO] [matrix.club-tech.fr] acme: Trying to solve HTTP-01
Jul 07 11:51:47 matrix-club-tech caddy[30374]: 2020/07/07 11:51:47 http: TLS handshake error from 54.37.23.75:51050: no certificate available for 'matrix.club-tech.fr'
Jul 07 11:51:47 matrix-club-tech caddy[30374]: 2020/07/07 11:51:47 http: TLS handshake error from 54.37.23.75:51052: no certificate available for 'matrix.club-tech.fr'
Jul 07 11:51:49 matrix-club-tech caddy[30374]: 2020/07/07 11:51:49 http: TLS handshake error from 54.37.23.75:51054: no certificate available for 'matrix.club-tech.fr'
Jul 07 11:51:49 matrix-club-tech caddy[30374]: 2020/07/07 11:51:49 [INFO] Deactivating auth: https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/73664028
Jul 07 11:51:49 matrix-club-tech caddy[30374]: 2020/07/07 11:51:49 [INFO] Unable to deactivate the authorization: https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/73664028
Jul 07 11:51:49 matrix-club-tech caddy[30374]: 2020/07/07 11:51:49 [ERROR] error: one or more domains had a problem:
Jul 07 11:51:49 matrix-club-tech caddy[30374]: [matrix.club-tech.fr] acme: error: 400 :: urn:ietf:params:acme:error:connection :: Fetching https://127.0.0.1/.well-known/acme-challenge/coH63QyLNqoL6-lmczedWKucOntmUrf6dZPMIMTgnRc: Invalid host in redirect target "127.0.0.1". Only domain names are supported, not IP addresses, url:
Jul 07 11:51:49 matrix-club-tech caddy[30374]: (challenge=http-01 remaining=[tls-alpn-01])
Jul 07 11:51:50 matrix-club-tech caddy[30374]: 2020/07/07 11:51:50 http: TLS handshake error from 54.37.23.75:51056: no certificate available for 'matrix.club-tech.fr'
Jul 07 11:51:51 matrix-club-tech caddy[30374]: 2020/07/07 11:51:51 [INFO] [matrix.club-tech.fr] acme: Obtaining bundled SAN certificate given a CSR
Jul 07 11:51:52 matrix-club-tech caddy[30374]: 2020/07/07 11:51:52 [INFO] [matrix.club-tech.fr] AuthURL: https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/73664083
Jul 07 11:51:52 matrix-club-tech caddy[30374]: 2020/07/07 11:51:52 [INFO] [matrix.club-tech.fr] acme: use tls-alpn-01 solver
Jul 07 11:51:52 matrix-club-tech caddy[30374]: 2020/07/07 11:51:52 [INFO] [matrix.club-tech.fr] acme: Trying to solve TLS-ALPN-01
Jul 07 11:51:52 matrix-club-tech caddy[30374]: 2020/07/07 11:51:52 http: TLS handshake error from 127.0.0.1:42492: EOF
Jul 07 11:51:55 matrix-club-tech caddy[30374]: 2020/07/07 11:51:55 http: TLS handshake error from 54.37.23.75:51070: no certificate available for 'matrix.club-tech.fr'
Jul 07 11:51:57 matrix-club-tech caddy[30374]: 2020/07/07 11:51:57 [INFO] Deactivating auth: https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/73664083
Jul 07 11:51:58 matrix-club-tech caddy[30374]: 2020/07/07 11:51:58 [INFO] Unable to deactivate the authorization: https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/73664083
Jul 07 11:51:58 matrix-club-tech caddy[30374]: 2020/07/07 11:51:58 [ERROR] error: one or more domains had a problem:
Jul 07 11:51:58 matrix-club-tech caddy[30374]: [matrix.club-tech.fr] acme: error: 403 :: urn:ietf:params:acme:error:unauthorized :: Cannot negotiate ALPN protocol "acme-tls/1" for tls-alpn-01 challenge, url:
Jul 07 11:51:58 matrix-club-tech caddy[30374]: (challenge=tls-alpn-01 remaining=[])
Jul 07 11:52:00 matrix-club-tech caddy[30374]: 2020/07/07 11:52:00 [ERROR] attempt 1: [matrix.club-tech.fr] Obtain: [matrix.club-tech.fr] error: one or more domains had a problem:
Jul 07 11:52:00 matrix-club-tech caddy[30374]: [matrix.club-tech.fr] acme: error: 403 :: urn:ietf:params:acme:error:unauthorized :: Cannot negotiate ALPN protocol "acme-tls/1" for tls-alpn-01 challenge, url:
Jul 07 11:52:00 matrix-club-tech caddy[30374]: - retrying in 1m0s (18.480022652s/720h0m0s elapsed)...
Jul 07 11:52:03 matrix-club-tech caddy[30374]: {"level":"info","ts":1594122723.7889454,"msg":"shutting down apps then terminating","signal":"SIGTERM"}
Jul 07 11:52:03 matrix-club-tech caddy[30374]: 2020/07/07 11:52:03 [INFO][cache:0xc000247b00] Stopped certificate maintenance routine
Jul 07 11:52:03 matrix-club-tech caddy[30374]: {"level":"info","ts":1594122723.7907484,"logger":"admin","msg":"stopped previous server"}
Jul 07 11:52:03 matrix-club-tech caddy[30374]: {"level":"info","ts":1594122723.7910244,"msg":"shutdown done","signal":"SIGTERM"}
Read up on docs, try to make my config file as simple as possible, ask a friend who’s been admining his own instance of Caddy 2, but no luck.
Not sure there’s anything to link in here?
