Caddy seems to keep old system handles in docker when using volumes
Caddy in Docker seems to open and handle to the root dir before the volume mount is performed. Therefore it is working with the now ‘shadow’ directory, not with the visible dir that got mounted in.
There is no log. All what I did to prove my point was using to add an local file into the directory in question (/var/www/html) and then run caddy.
I always got the file in the original dir, never that one that should had been mounted by docker compose.
Caddy:
:8080
root * /var/www/html
php_fastcgi php-fpm:9000
docker-compose.yaml
mycaddy:
    image: caddy:latest
    container_name: mycaddy
    hostname: caddy
    restart: always
      - "8089:8080"
      - htvol:/var/www/html
    depends_on:
      - php-fpm
See docker compose above
6. More
I found an workaround to this issue: If your file_server has ‘browse’ set, caddy seems to finally refresh. But only AFTER you displayed the browse listing at least once.
And yes. I also tried to mount to the official mounting point “/data” - same story.
I’m not sure if you have found something other than the workaround, but there’s a few solutions I think I found that could help.
You could copy your website files into the volume during the image build process with a Dockerfile.
FROM caddy:latest
# Create the directory in the image
RUN mkdir -p /var/www/html
# Copy your website files into the directory in the image
COPY ./website_files /var/www/html  # ./website_files is the directory on your host
# Caddyfile can stay the same from the original posted Caddyfile
Then run:
docker build -t my-custom-caddy
Then use the custom image:
mycaddy:
  image: my-custom-caddy
You could also try mounting ./website_files:/var/www/html
