I’m trying to use snippets so that I can use my cloudflare origin certificate for sites that will sit behind cloudflare, and use ACME certificates from my ACME server for other sites.
I have got the ACME snippet working with other sites, but when I use the import
command to use the snippet I wrote for cloudflare sites with ANOTHER host, a site that doesn’t have this import
statement suddenly starts using the wrong certificate, causing errors as the cloudflare origin CA isn’t trusted by my browser!
v2.7.6
Docker container
Docker container
http_port 80
https_port 443
(graylog-logging) {
log graylog-logging {
output net udp/graylog:12400
format json
(cloudflare-host) {
## Blocking requests not originating from cloudflare IP adresses ##
@not-cloudflare-ip not client_ip 173.245.48.0/20 103.21.244.0/22 103.22.200.0/22 103.31.4.0/22 141.101.64.0/18 108.162.192.0/18 190.93.240.0/20 188.114.96.0/20 197.234.240.0/22 198.41.128.0/17 162.158.0.0/15 104.16.0.0/13 104.24.0.0/14 172.64.0.0/13 131.0.72.0/22 2400:cb00::/32 2606:4700::/32 2803:f800::/32 2405:b500::/32 2405:8100::/32 2a06:98c0::/29 2c0f:f248::/32 192.168.5.0/24 192.168.10.0/24
## TODO: put a good 403 page on ##
handle @not-cloudflare-ip {
header Content-Type text/html
respond "<h1>403 - Access Denied</h1>" 403
## Use our custom cloudflare origin TLS cert ##
tls /data/caddy/custom-certs/cf-origin/cf-origin.pem /data/caddy/custom-certs/cf-origin/cf-origin.key
(step-ca-acme-cert) {
## Uses my internal CA to get certs via ACME! ##
issuer acme {
dir https://ca.infra.lab.liamriley.me:8443/acme/acme/directory
trusted_roots /data/caddy/custom-certs/step-ca/step-ca.pem
disable_http_challenge
weather.liamriley.me {
import graylog-logging
#import cloudflare-host
reverse_proxy * http://192.168.5.38:80
reverse_proxy /weatherws http://192.168.5.38:7890
@admin-request path /admin*
handle @admin-request {
mail.liamriley.me {
import step-ca-acme-cert
## Redirect the web root (/) to /SOGo, as this is the only content we are proxying! ##
redir / /SOGo/
reverse_proxy * http://nginx-mailcow:80
