Caddy saving data to entire website
I am trying to fix this problem for days, like I have no Idea so like when I visit my website in first place it looks normal like, it’s normal “caddy server” but when you do anything like make something like login or sign up it affects the entire Caddy Server your website login credencials will be there like you login, it affected the entire website when you go to different device it’s your account there people can go destroy your account they can do what ever they want.
Like it’s really annoying it affects entire site by doing anything on site, like you did something it affected on entire site no matter even you on different device it will give you the data from other device not other device actually entire site data.
Caddy doesn’t really save this kind of data.
It’s impossible to speculate on what might be going wrong on your end without more specific information, sorry.
Yeah you actually right I was wrong for some reason because I am starting out so it was on a website not on caddy so actually the issue problem was on the website were I was made it that home page contains user data which is random chunk of url so I was wrong.
